Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 03-24-2004, 01:22 AM   #1
remcolent
Profile:  1986 32' Excella
vledder , drenthe
steel or stainles steel screws
on the exterior everything is fastened with now rusted steel screws
lights, awning , doorhinges
can I use stainles steel screws and bolds or will this material give a nasty reaction with the aluminium skin
Remco
remcolent is offline   Reply With Quote
Old 03-24-2004, 02:36 AM   #2
53flyingcloud
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
1964 19' Globetrotter
1953 21' Flying Cloud
Amherst , New Hampshire
Been there and done that
remcolent
Last year, as a part of my project for cleaning up the exterior, I replaced all of the rusting steel screws with stainless steel screws.
Only time will tell but, for now it certainly looks BETTER~!!
I don't recall the thread but, there was a picture posted on the forum of an older A/S that suffered badly around the exterior light from the effects of rusting steel on aluminum.
Plus, I feel better also..
I've read all the articules about the effects of dissimilar metals and, figure if I'm going that route to start with, it just as well be stainless.
ciao
AIR 807
53flyingcloud is offline   Reply With Quote
Old 03-24-2004, 06:53 AM   #3
sander17
sander17's Avatar
Profile:  1996 28' Excella
Okemos , Michigan
Images: 42
Thumbs up Aluminum and Stainless steel
Stainless steel fasteners are a good match to aluminum. The standard material for helicoil thread inserts in aluminum is stainless. Only one thing to remember: when using a SS nut with a SS bolt, always use a little dab of Antisieze. If you crank down on a dry joint, the nut will weld itself to the bolt and gall when it comes time to remove it.
sander17 is offline   Reply With Quote
Old 03-24-2004, 07:13 AM   #4
74Argosy24MH
Profile:  LOST , Hawaii
This is a chart showing how various metals will react to each other. I agree, use stainless. I use it everywhere inaccessible or exposed to water/salt.
John
74Argosy24MH is offline   Reply With Quote
Old 03-24-2004, 07:29 AM   #5
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
In stainless we trust....all others will rust!
Old 03-26-2004, 06:58 PM   #6
Tarheel
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
We used aluminum rivets or SS screws for work on the aluminum on boats and ships. When we had to secure an aluminum superstructre to a steel deck we put a rubber barrier between the steel and aluminum and then used SS fasteners.
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 03-26-2004, 09:42 PM   #7
imeynstein
imeynstein
imeynstein's Avatar
Profile:  1974 31' Sovereign
Texarkana , Arkansas
Rivet stainless steel screws
Has anyone used the stainess steel screws with the rubber washers? If so, did you also follow through with a sealant, or can this be omitted since the rubber washers are supposed to form a water-tight seal? I am thinking of removing my roof antenna and am thinking of alternatives to riveting....
imeynstein
imeynstein is online now   Reply With Quote
Old 03-26-2004, 10:04 PM   #8
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
The original base I believe is screwed to the skin. I would do the same and use plenty of vulcem between the antenna base and the skin as well as potting the screws once they are installed.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 03-29-2004, 08:10 PM   #9
p.dow
Profile:
alum. screws ?
i replaced our rusted sheet metal screws that had weeped discolor onto the sideing with alum. sheet metal screws we got at ace hardware.
looks are greatly improved.
paul
p.dow is offline   Reply With Quote
Old 03-29-2004, 09:05 PM   #10
imeynstein
imeynstein
imeynstein's Avatar
Rivet
I plan on using the stainless steel screws when I replace the hot water heater. Has anyone replaced their hot water heater with one of those tankless hot water heaters?
imeynstein
Old 03-29-2004, 09:26 PM   #11
Over59
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
Great link with the metal to metal reaction. Thanks.
Let those who can play, let those who cann't rule.
Over59 is offline   Reply With Quote
Old 03-30-2004, 07:54 AM   #12
Tarheel
Tarheel's Avatar
Images: 21
Stainless Steel is a little more expensive, and when you are in a hurry or need them righ now some of the local hardware (if there is still such a thing in your neighborhood) sometimes don't carry them. They are worth the extra expense, and all of your boat supply places carry them and other SS hardware that is hard to find elsewhere.
WBCCI # 3485
Region 3 1stVP
test
