Old 12-03-2008, 01:34 PM   #1
GR8DANE's Avatar
1966 22' Safari
1964 24' Tradewind
1956 18' "Footer"
Southern , Minnesota
standard practice from the factory in '66?
Here's a couple of pics of the ribs as seen through the vent stack openings toward the rear of my '66 Safari. I'm sure someone can tell me if they will need attention or whether it's not an issue.
Continuing thanks to the braintrust that is airforums...
ID:	72120   Click image for larger version
life is too short to drink cheap beer...unless that's all we've got and then pass me a cold one!
Steve "Dancin" Hansen
TAC MN-31
visit my almost yearly blog http://www.bluessafari.blogspot.com
GR8DANE is offline   Reply With Quote
Old 12-03-2008, 03:36 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Can you describe the orientation of the holes a bit more. Are they plumbing stacks and through the roof or something through the side wall?
2004 Excursion 4x4
Old 12-03-2008, 04:48 PM   #3
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
I see this more than once before! I always joked it must of been done at shift change or "green pea" Or late on Friday!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 12-03-2008, 04:58 PM   #4
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Looking at it I'm guessing we're looking at the first rib after the end cap too, where the fiberglass transitions to aluminum. Thats one of the big structure points I would assume. Also means you have a major aluminum seam to get in there and work without too much more to remove. probably a dozen rivets and you can peel the aluminum back, sister on some new metal (on the side away from the pipe) and button it back up and feel better knowing you have something structurally much closer to what was engineered.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 12-03-2008, 05:15 PM   #5
lynn's Avatar
It seems to have made it 42 years. Is it through the center of the rib or just the edge?
lynn is offline   Reply With Quote
Old 12-04-2008, 08:41 AM   #6
GR8DANE's Avatar
1966 22' Safari
1964 24' Tradewind
1956 18' "Footer"
yes, indeed, it is a vent stack opening and it appears that they cut through the part of the rib where the angle is formed. So skins out and attach a mending plate? Should the mending plate be aluminum and riveted in?
TAC MN-31
Old 12-04-2008, 08:59 AM   #7
goransons's Avatar
1963 22' Safari
just a few rivets and you should be able to let the skin hang out of the way, I wouldn't take the panel out entirely unless you ahve a lot of other work to do. I'd use aluminum C Channel or similar, it is a standard dimension available at metal suppliers, and aluminum rivets, that way you have similar metals in there, wood in time could rot, especially with as prone to leaking as the vents are.
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 12-04-2008, 12:14 PM   #8
GR8DANE's Avatar
1966 22' Safari
1964 24' Tradewind
1956 18' "Footer"
Many thanks, Goransons! It will be a project that I can get done inside the trailer while it snows outside...
TAC MN-31
Heatpump vs. Standard AC Safari Tim Furnaces, Heaters, Fireplaces & Air Conditioning 56 04-25-2007 08:32 AM
Is this standard layout bertro Repairing/Replacing Floor &/or Frame 2 04-13-2007 08:03 PM
How many stabilizer jacks are standard? Janet H All Argosy Trailers 3 03-13-2004 10:09 PM
Towing with Standard Trannie DMAYRES On The Road... 7 12-04-2003 08:15 AM
Standard vs. option? silverback 1997 - 2004 Bambi 7 07-19-2003 02:00 PM
