Old 03-18-2011, 10:46 AM   #29
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Originally Posted by tinman54 View Post
The inside skin is still off right now, I will be installing that in the next few weeks.
Vintage trailer supply has a wide flange rivet for underneath. though it has a hole, you would expect water to drain out, not in, through the bottom. The center hole makes it much easer to drill out and inspect if needed. Buck rivets can be a little more tricky to drill out. Just a thought - Rob.
robwok is offline   Reply With Quote
Old 03-22-2011, 05:07 PM   #30
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Originally Posted by filterman View Post
What about aircraft grade aluminum phillips screws???
See.. that is too obvious and makes too much sense..
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 03-22-2011, 05:44 PM   #31
Images: 59
10 points to the first person that provides a link to "screw, aircraft grade, aluminum, phillips".
Either flat head or pan head will suffice.
Start. . . . . . . .NOW!
Old 03-22-2011, 06:14 PM   #32
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Anyone look at McMaster Carr or Fastenal?
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 03-22-2011, 06:59 PM   #33
DanielB's Avatar
These would probably do just fine.
Fastener Express - Socket Head Cap Screws, Metric Screws , Fasteners and Anodize - Aluminum Fasteners Nuts Washers
Come in different colors and come in plain or anodized aluminum.
- Andrew Carnegie
Old 03-22-2011, 11:22 PM   #34
Stubborn but learning
filterman's Avatar
1973 31' Excella 500
washougal , Washington
Screws
Look here its a start. My buddy used to be a boeing plane inspector he thought they could be found. Sorry been busy or I would have searched harder for ya. Looks like I got beat to the finish line. Make shure you thread lock those screws they will need red thread locker from 3-m not the blue it wont hold on aluminum.
filterman is offline   Reply With Quote
Replacing Steel Wheels with Aluminum crookedroad Wheels, Hubs & Bearings 8 02-03-2011 11:27 AM
Need help removing rivets. Breadbug Windows & Screens 16 01-19-2011 08:11 PM
Larger Interior Rivets? MDSilverado Ribs, Skins & Rivets 3 01-10-2011 06:54 AM
aluminum or steel rayandre LP Gas, Piping, Tanks & Regulators 3 01-01-2011 11:55 AM
