Old 03-20-2012, 07:13 AM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
Stainless Hand Rivet Squeezer??
Greetings all:
I am in the final phases of gutting my Bambi II for floor replacement. I began taking the inner wall aluminum off last evening and am good to go on regular pop rivets, but I am struggling with whether or not to remove the buck rivets around the entrance doorway which hold the inner aluminum on. Problem is I never buck riveted before (though I know I could learn) and these are the only buck rivets I would need to replace. I don't really want to spend the money on a buck riveting setup when this is very likely the only Airstream I will ever re-do.
So I was tooling around VTS's website and looking in the riveting section and found a hand tool for setting solid rivets: Stainless Hand Rivet Squeezer.
I was wondering if anyone has any experience with this tool? Seems it would do the job I need it to do as the only buck rivets I need to remove and reinstall are those around the entrance doorway which are very accessible front and back. I plan to use Olympics elsewhere on the exterior shell.
Thoughts or opinions?? Thanks! Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 03-20-2012, 07:23 AM   #2
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
The Hand Squeezer works good for the rivets at the door but make sure you get the soft "A" rivets as it won't squeeze the hard "AD" rivets.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 03-20-2012, 07:31 AM   #3
1964 17' Bambi II
Thank you- would the ones sold through VTS work? As advertised: "We are currently selling our solid rivets in the soft 1100F alloy used on most Airstreams."
Ben
Old 03-20-2012, 07:38 AM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Works great for rivets that you can get to both sides of. You will only be able to use it on the edges - in as deep as it is wide. We have one and used it at the wheel wells and doorway - great tool!
Shari
ID:	153968   Click image for larger version
Old 03-20-2012, 05:54 PM   #5
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Ben
Yes, the 1100 alloy is the softer rivet that you can use the hand squeezer on. I usually get rivets from Aircraft Spruce as there is one near me.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Old 05-04-2012, 08:55 AM   #6
1963 16' Bambi
Erlanger , Kentucky
Doug, I notice the number of vintage Airstreams that you have. I currently am completing a full rehab on a 63' Bambi. My plan is to do another model. What vintage model do you recommend I start on.
Marty
Crestview Hills, KY
mattismp is offline   Reply With Quote
Old 05-04-2012, 09:57 AM   #7
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Marty
Crestview Hills, KY
Marty, to be worth all the work, you need to get another Bambi or Caravel or an early 50's. If it's something you want to keep, like our 60 Ambassador then a longer trailer is great for using. We have our Ambassador set up to be comfortable for longer trips.
Doug
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Buck rivet gun question mrgreen Ribs, Skins & Rivets 8 03-16-2012 12:27 PM
Rivet Type - Door Strike Plate bganso Doors & Locks 2 03-14-2012 09:33 PM
Insulating paint and stainless steel coating??? Chlyman General Repair Forum 3 03-06-2012 05:40 PM
Solid rivet questions pityocamptes General Repair Forum 5 03-02-2012 05:38 PM
Stainless/Aluminum Wall Cladding Stonew98 Upholstery, Blinds, Walls & Interior Finishes 4 02-25-2012 07:28 AM
