Old 08-27-2010, 08:58 AM   #1
1974 25' Tradewind
Berryville , Virginia
source for aluminum trim
Anybody have a source for the aluminum trim used on 74 Trade Wind. I need 8' of both the 2" bottom trim and the 1-1/4" mid level trim. Also need the blue tape. I did not see it on Either Vintage or Out of Doors Mart.
batt is offline   Reply With Quote
Old 08-27-2010, 09:57 AM   #2
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Did you try Inland RV? Andy will be able to tell you if it's available.
SilverHoot is offline   Reply With Quote
Old 08-27-2010, 10:04 AM   #3
The rub rail (bottom) and belt line (middle) moldings come in 16 foot lengths.
They can be cut in half to minimize shipping costs.
The blue color is a vinyl insert, not a tape. This applies to a 1974 model. Tape was last used in 1971, and for 72 and 73, the inner part of the moldings were painted blue.
Old 08-27-2010, 10:13 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Andy, would the rub rail you have match the rub rail on my '72 Sovereign?
Chris
Old 08-27-2010, 10:34 AM   #5
Chris
Chris.
The type moldings that were used from 1973 and back, have not been available for maybe 15 to 20 years. No one will have the exact original replacement.
You can update the trailer using the insert type, for the rub rail but the belt line molding that is now available is not as wide as the original.
Also, the present moldings, are anodized, therefore the color of the aluminum moldings is a few shades diffent than the originals.
Some owners replace all the moldings to update the coach. Some others, look for a salavged coach for a used part.
Old 08-27-2010, 03:32 PM   #6
Minno's Avatar
1972 31' Sovereign
Thanks for the info Andy. I'm missing about a foot of the rub rail that goes behind the water heater. I think I'm going to cut the rear section of rub rail and patch it along the side so at least the entire side is all the same. And then do something different above the bumper. Or maybe I'll use the front piece since I'm putting a battery box on the a-frame and the rub rail will be hidden.
Old 08-27-2010, 04:02 PM   #7
That will work.
Vinyl Trim Tape Source 84Sovereign Clearcoat, Exterior Paint & Trim 2 05-04-2010 08:36 PM
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 06:19 PM
Source for aluminum counter trim... 59er Upholstery, Blinds, Walls & Interior Finishes 5 09-24-2008 10:37 PM
Source for moulding trim gaylejoe General Interior Topics 4 09-16-2006 01:39 PM
Trim tape source(s)? RoyRK Clearcoat, Exterior Paint & Trim 2 06-03-2004 08:29 PM
