Old 07-18-2012, 11:18 AM   #1
Eagle & Bear's Avatar
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
Source for Alclad sheet
Where can we buy pieces of Alclad for AS exterior work? We are in Flagstaff AZ. I need four 10 inch wide strips to "coverup" a cosmetic scratch on the side of a 1976 International. Some of the scratch runs between the two trim strips on the side of the trailer. Two of the strips have to be 9 feet long and two have to be four feet long. Since I am not familiar with how Alclad is guaged for thickness I would like the material to be slightly thinner than the original side material.
Name:	Airstream side2.jpg
Eagle & Bear is offline   Reply With Quote
Old 07-18-2012, 11:28 AM   #2
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Polish them out. By the time you buy the patch, the rivets and the shaver, and the hours of work. You could rent a cyclo, polish it out and be camping in less time.
Phrunes is offline   Reply With Quote
Old 07-18-2012, 11:40 AM   #3
1976 29' Ambassador
Thanks Phrunes. Unfortunately the scratches are too deep to polish out. It might be possible for me to cover the worst scratches using a sheet of Alclad between the trim strips on the side.
Old 07-18-2012, 11:42 AM   #4
1976 29' Ambassador
I forgot to ask...what is the thickness of the original Alclad exterior siding for 1970 models?
Old 07-18-2012, 12:00 PM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
The skin thickness is .032, the next down is .025, then .020, most places will not sell a 10" wide strip nine feet long. You would have to buy a 4" wide sheet and cut it. Check out AirParts.com - Home Page for a source
Old 07-18-2012, 12:48 PM   #6
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
On-line metals will do custom cuts. Didn't see anything as long as you need though.
Order Aluminum 2024 Sheet in Small Quantities at OnlineMetals.com
Give them a call and see if they've got something that will work for you.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 07-18-2012, 06:48 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Might want to put a micrometer on your skins... I have a 1975 an mine are .040, at least the ones I have measured. I use Airparts Inc for my Alclad sheet metal.
Aaron
WBCCI #XXXX AIR #2495
Old 07-24-2012, 04:58 AM   #8
1976 29' Ambassador
Air Parts offered the best price and shipped it to the sheet metal shop where they will cut it for me. Thanks
Old 07-24-2012, 07:26 AM   #9
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Another source is Aircraft Spruce. I found with a recent purchase that their material + shipping was better than some others. I expect you would have to buy a 4' wide sheet from them as well.
Old 07-24-2012, 07:37 PM   #10
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
Eagle and Bear,
I wish you the best with your repair. Keep us posted! Take some pictures along the way and when you get finished!
Steve
Steve Bryant is offline   Reply With Quote
Old 07-24-2012, 09:06 PM   #11
r carl's Avatar
Lin , Ne
Your international may be .032 6061-T6 which would be easier to find.
Old 07-25-2012, 08:06 AM   #12
1991 34' Limited
Wichita , Kansas
r carl,
These are veryinformative documents and I've saved the pdf files. Thank you very much!
Steve
Old 07-25-2012, 06:45 PM   #13
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
The local industrial and commercial insulation contractor may have various thicknesses kicking around his shop. Take him some coffee and donuts and he may just give you some pieces.
Jim Flower is offline   Reply With Quote
