Old 05-17-2006, 09:20 PM   #1
AnnabeltheCaravel
chalcedon's Avatar
1967 17' Caravel
Solid rivet length
Hey there.
What length solid rivets should i use to re-attach Annabel the caravel's shell to the c channel.
Thanks.
Eric...
chalcedon is offline   Reply With Quote
Old 05-17-2006, 11:09 PM   #2
Images: 59
I use 5 length. The formula for calculating is:
Rivet length = Thickness of materials + 1.5D
Where D is the rivet diameter.
In the case of my '59, the body/belly/channel are all .032", and I used 5/32" rivets, so the length would be 3×.032" + 1.5×0.156", or 0.3304".
Convert .03304" to 16ths gives a length of 5. (Rivets diameter is in 32nds, and length is in 16ths)
I used about 1 lb of 5 length, 1/2 lb of 6 length, and about 1/4 lb of 7 length.
You could also buy a rivet cutter and cut them to whatever length you need.
Old 05-18-2006, 07:27 AM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Markdoane,
Is 5/32 the standard exterior driven rivet diameter? I'm about to ditch my Vista View ports and will need to use the same holes to attach a replacement plate. For some reason, the driven rivets around the Vista Views "look" bigger than 5/32.
Roger
Old 05-18-2006, 08:08 AM   #4
Images: 59
Roger,
I haven't worked on Vista View windows, so I don't feel I can answer your question.
The original rivets in my trailer were 1/8" Brazier Head rivets, which I am replacing with 5/32" Universal Head rivets. Both have the same head diameter, so they look similar.
Olympic rivet removal and installation PeterH-Airstreamer Ribs, Skins & Rivets 90 11-07-2012 01:34 PM
How durable is a Cyclo polisher? What about a rivet shaver? Andy R Cleaning, Stripping & Polishing 13 09-13-2011 05:56 AM
Best rivet tool? Andy R Ribs, Skins & Rivets 9 09-24-2006 07:36 AM
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 05:51 PM
