Old 08-05-2011, 07:24 AM   #1
1994 34' Excella
Greenbank , Washington
Smoothing Down Rivets
Good Morning All!
A newbie question:
I put some pop rivets in some spots that needed them, and noticed a little part of the rivet sticks out. Is this normal?
Looking at previous threads, there is something called a rivet shaver mentioned, which I don't have (I don't even know what it is, or where to get one, frankly). Can I use something else, or maybe hacksaw or file these off?
Thanks in advance!
Airy is offline   Reply With Quote
Old 08-05-2011, 07:34 AM   #2
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Pop rivets should not have left the stem in. Perhaps you can grab & pull them out with pliers. IF they are Olympic rivets then a rivet shaver is the way to go. I got mine from Aircraft Tool Supply. It is expensive but does such a great job. Some forum members have had success using a Dremmel grinder. Do a search on rivets and you will come up with much material to look over.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 08-05-2011, 08:13 AM   #3
1994 34' Excella
Smoothing Olympic Rivets
Thanks for the reply.
They are Olympic Rivets, which evidently leave a stem.
Can I just cut those off, I'd rather not have to buy a shaver tool, as I may not have a great need for such an expensive item.
Is there something else I can use?
Old 08-05-2011, 08:21 AM   #4
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
If you aren't putting to many in you can use a hand file to take that stem down. It goes fast The shaver is not cheap $200 Olympic HS310-5B Rivet Head Shaver
If you use a file be careful not to go to far or hit the your aluminum.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-05-2011, 01:14 PM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
A Dremel tool used carefully will work too, but we have a rivet shaver - it's more than worth the $$$ if you have more than a few dozen to do. At this point, I figure it has cost us right around 5 cents per rivet.
Shari
Rivets for awning leaking = $$ captmatt Ribs, Skins & Rivets 20 07-17-2011 05:58 PM
Can I use this riveter for bucking rivets? bennyg Ribs, Skins & Rivets 15 06-30-2011 08:07 AM
78 argosy interior rivets argosyman General Interior Topics 2 05-17-2011 11:49 AM
Larger Interior Rivets? MDSilverado Ribs, Skins & Rivets 3 01-10-2011 06:54 AM
