Old 06-27-2012, 12:03 AM   #1
mefly2's Avatar
2015 25' FB Eddie Bauer
Small dent repair - vacuum ?
Has anyone utilized the vacuum dent removal method for dent repair on small dents? We have one where the rock guard rivet got mushed into the front skin next to the hinge line (also took out the TV rear right turn lens. Can't imagine kissing a curb in a parking lot access from the street? Well I did - what an idiot! WE were backing up slowly at a sharp angle when the TV continued after the AS was stopped by the unseen curb.)
Old 06-27-2012, 12:26 AM   #2
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
This may look/sound crazy, but if you go to just about any pharmacy - you might find a 'handicap suction handle'. Kind of large and has two good sized suction cups at each end. Strong enough to support a grown person. This is one way to pop dents out. Cost? about twenty bucks. And even if it does not work - you can use it to raise your weary body up after polishing.lol
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 06-27-2012, 04:07 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Automotive stores have a product called "Dent King". Instead of vacuum, it uses hot melt adhesive to stick a "handle" onto the dent and you pull it out. It works on some dents and you can get the adhesive off with a hair dryer.
Old 06-27-2012, 09:48 PM   #4
mefly2's Avatar
Didn't get it 100% out; but I am 100% happy with the results ... many thanks for your help.
Old 10-06-2012, 06:53 PM   #5
2010 19' Flying Cloud
Salem , Oregon
mefly2, what did you do??
Can you send any detail on what you did? Which method did you use? Do you have any pictures?
willwalt. . .
Willwalt is offline   Reply With Quote
