Old 09-17-2007, 06:23 PM   #1
sumsmug's Avatar
1985 25' Sovereign
1966 17' Caravel
Philly , Pennsylvania
Small dent? New panel?
Hi All
browsing through the forums, it seems that most dents in the endcaps need new sections (at great cost). So I'm assuming the dent in this airstream is no different... however, I can hope that there is a less expensive alternative, like sucking out the dent, or beating it out from the inside. Has anyone tried this with such a dent?
This is a '89 excella 28 ft.
Cheers
SumsMug
ID:	45558   Click image for larger version
sumsmug is offline   Reply With Quote
Old 09-17-2007, 06:39 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Nothing to lose..
Your dents don't look too bad, though there is a crease in the one in the middle of the segment so it may have stretched the metal.
I'd say, get the hair dryer, the plunger and the glass pulling suction cups and have a go - gently and slowly. If you don't feel confident to try it yourself, find someone who works on airplanes - they can do wonders with aluminum.
You probably won't get it perfect, but surely there's room for major improvement. If you USE an Airstream it will never stay "perfect" so even if you have a few scratches or a small ding left over, who really cares?
Paula
Old 09-17-2007, 06:42 PM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Plunger!
Hi Sumsnug, It looks like the small lower dent could be pulled with a plunger with some success. The large one looks creased, a little more difficult. Maybe someone else has some ideas on that one.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 09-17-2007, 07:38 PM   #4
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I had good results working out a bunch of dents from the inside with this tool. Do not ever put a hammer to the aluminun as it will only make it worse.
ID:	45569   Click image for larger version
Old 09-17-2007, 07:43 PM   #5
Alumatube's Avatar
1984 31' Airstream310
New Holland , Ohio
I think it was Terry (overlander63) who said he had good success with rolling a partially deflated basketball on the dents from the inside (after removal of the inner end cap, of course). If you search you might find that thread (I'll have a look to see if I can).
Sorry about your dents! We have some pretty hefty ones in our moho endcap as well, from the previous owner.
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Old 09-17-2007, 07:48 PM   #6
1979 24' Airstream Excella 24
Fayetteville , Georgia
Take the inside apart,hammer her back out(dead-blow hammer)
CamperRepair is offline   Reply With Quote
Old 09-17-2007, 08:18 PM   #7
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
You can probably push it out from the inside with a roller (see previous post). A significant amount of work. It will not completely dis-appear. the metal is already stretched beyond its initial forming.
Michelle TAC MT-0
Sarah, Snowball
Old 09-19-2007, 08:17 AM   #8
raveson's Avatar
1989 34.5' Airstream 345
boca raton , Florida
A few years back, had a dent wisard fix the same type of dent on my then 66 landyacht. Worked great! The dent guy drilled a hole in the window frame and used his tools from that point only. When completed, he pluged the hole with a cap. The dent was 98% fixed within a hour or so.
raveson is offline   Reply With Quote
Old 09-19-2007, 08:36 AM   #9
GStephens
GStephens's Avatar
1982 31' Limited
1953 25' Cruiser
Hamilton , Texas
I'm afraid you won't have much luck in removing either dent. The lower one is on a support (see rivet line). That support will have to be repaired before anything will align back up. The upper one is creased. The crease will never come out no matter what you do.
GStphens
GStephens is offline   Reply With Quote
Old 09-19-2007, 08:42 AM   #10
Central , Mississippi
I'm with Aerowood, If you can get to the inside roll it out. I made a similar roller from a worn out skate board wheel and did my Banana wrap last weekend. Roll in small sections and start at the edge working the dent around it's perimeter toward the crease. It may only get 95% of the dent out but it will look 100% better.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 09-19-2007, 10:17 AM   #11
Originally Posted by sumsmug
Hi All
Cheers
SumsMug
Those dents can be rolled out, but then that's what they will look like too.
To get at the back side of those segments, you will need to remove the headliner, and a few more things with it, just to gain access.
Old 09-19-2007, 10:21 AM   #12
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Aerowood,
Where can I buy this tool and what is it called?
Bill
Just my personal opinion
Old 09-19-2007, 11:31 AM   #13
sumsmug's Avatar
1985 25' Sovereign
1966 17' Caravel
Thanks all
We will give it a go next week, and post pictures of before and after (if not too gruesome)
Regards
SumsMug
Old 09-19-2007, 11:36 AM   #14
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Thanks all
Regards
SumsMug
Oh come on! We wanna see the gruesome shots too!!!!
If for no other reason but to show us what not to do ~ have you seen some of those "inadequate tow vehicle" threads? Talk about gruesome...
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
how bad is too bad a dent? prairieschooner Exterior Restoration Forum 26 07-21-2010 01:40 PM
Dent flyguy Ribs, Skins & Rivets 19 06-08-2007 12:46 PM
First Dent - HELP! JimGolden Ribs, Skins & Rivets 10 01-08-2007 12:47 PM
Big Dent JIM Bowers Ribs, Skins & Rivets 4 01-16-2006 07:13 AM
dent down low John Greenlee Ribs, Skins & Rivets 5 03-27-2004 07:29 AM
