Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 08-18-2004, 07:34 PM   #71
Ken J
Profile:  1958 26' Overlander
Tijeras , New Mexico
What a way of getting out of polishing your trailer!
Anyway, how did you drill out your rivit holes in the new big panel? Did you make new holes in the frame or did you try to find the old ones?
Ken
1958 Overlander
Ken J is offline   Reply With Quote
Old 08-18-2004, 07:42 PM   #72
Ken J
.040" as in panel thickness?
1958 Overlander
Old 08-18-2004, 07:56 PM   #73
greg176
greg176's Avatar
Profile:  1961 26' Overlander
Gabriola Island , British Columbia
On another recent thread Andy had reccommended .040 thick aluminum when replacing side panels.a good idea for the sides.It would be a little tougher and would lay flatter than the 032.
To pick up holes I drilled though existing holes on overlapping top panels.I replaced all stringers and lower "U" channel so all new holes from inside.To get holes in frames I had my wife back up panel on outside and center punched holes from inside with a punch bent 90 degrees.I did not want to drill new holes in frames and weaken them.
greg176 is offline   Reply With Quote
Old 08-18-2004, 08:00 PM   #74
markdoane
Profile:  , Minnesota
Images: 59
Greg,
That is beautiful! What did you use to seal the fay surfaces? Vulkem, Sikaflex, Thiokol or ??
Non-contributing deadbeat.
Old 08-18-2004, 08:12 PM   #75
greg176
greg176's Avatar
On the aft panel I used Vulkem.I ran out of Vulkem and used Sikaflex on the side panel.I prefer the Vulkem by far.The Vulkem stays wet for most of the day which is better for the rivets sealing as they are installed.In the heat and humidity I had here the Sikaflex is drying almost as it comes out of the tube ,a real pain.Clean up is much easier with Vulkem,could use varsol.With the sikaflex I had to use lots of MEK.I would only reccommend Sikaflex for edge sealing a panel or window.I'll use up what I have but never again.
At work they use a polysulfide sealant that has a 20 hr pot life.When I get back from vacation I'll see if I can get some expired sealant for other panels.
Old 08-18-2004, 08:15 PM   #76
Ken J
Thanks - you answered my original question! My concern initially was making swiss cheese out of frames/stringers.
Ken
1958 Overlander
Old 08-18-2004, 08:17 PM   #77
Ken J
Actually one more question - could you drill out holes from the inside using the original frame holes as a guide rather the center punching?
1958 Overlander
Old 08-18-2004, 08:27 PM   #78
greg176
greg176's Avatar
Because of the "c" shape of the frames you cannot pick up holes by drilling from inside without an angle drill.I could not borrow one while I was on vacation but will when I am back to work next week for other panels.
http://www.aircraft-tool.com/shop/de...t.asp?PageNo=2
Old 08-19-2004, 07:27 AM   #79
Ken J
I was hoping that I could use a long drill bit - seems to me you could drill 1/8 then open up to a larger hole from the outside - do you think this would work?
Ken
1958 Overlander
Old 08-19-2004, 08:05 AM   #80
greg176
greg176's Avatar
Because of the shape of the channel the drill would come out of the panel at an angle off to one side of the hole.
Old 08-19-2004, 11:46 AM   #81
markdoane
Images: 59
Ken
Pretty risky. If you held the bit tight against the outside leg, and cheated a bit to the outside of the inner leg, you would still end up with a hole that is wider than 5/32" but less than #21. Actual dimension if you tried to square it up from outside would be 0.1577" Not enough to be a problem, but each one would have to be perfect.
If you go to the center of the channel inner leg, the width becomes 0.1671", which is bigger than a #19.
Old 08-24-2004, 04:05 PM   #82
greg176
greg176's Avatar
Now that the streetside is done I'm moving onto the roof.i spent the last few days removing the air conditioner and the rest of the interior panels.Now I can see what happened to the trailer.It looks like a tree fell on it at one time and it was repaired with those explosine rivets.They spliced new rear sections of three top panels.The original three top panels were one piece each.Two of the frames had new curved sections spliced in and a third is in bad shape and should have been replaced.All of the joints were put together dry and leak a lot.It was raining heavy today and I could see water coming in at all joints with explosive rivets.
ID:	8499  Click image for larger version
ID:	8501  Click image for larger version
ID:	8503  Click image for larger version
ID:	8505  Click image for larger version
Old 08-24-2004, 04:18 PM   #83
Ken J
VERY nice work... are explosive rivets the same as Olympics?
Also how long did it take to replace the big side sheet?
Ken
1958 Overlander
Old 08-24-2004, 11:51 PM   #84
greg176
greg176's Avatar
KEN , The fourth picture above is of an explosive rivet.They are no longer available.They are a soft aluminum rivet.You would install the rivet then hold a soldering iron to the rivet to ignite charge.They worked well but you had to get exact length or they wouldn't hold.
It took me about five eight hour days to replace the streetside panel.One day to drill off the old panel,two days to drill new and two days of riveting.
