Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 08-28-2008, 07:01 PM   #267
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Originally Posted by Ken J View Post
You should not have to enlarge the hole if you drill out the original rivets correctly - what you need to do is drill the rivet part way and then "pop" it out with a center punch - that way you don' enlarge the hole.
Ken J.
Understood...but there are always a couple! We used 99% 1/8" but we have some 5/32" on hand for those few "oopsies", it's not the end of the world.
Also, on our GT where the PO replaced a panel with Olympics...the overlapping holes on the good panels adjacent that are to remain are now oversized. I would think, it's always better to have the holes on the front & back panel the same size - less chance for "wrinkles" in that new skin.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
InsideOut is online now   Reply With Quote
Old 08-28-2008, 07:21 PM   #268
Ken J
Profile:  1958 26' Overlander
Tijeras , New Mexico
Yea - on a replaced panel that has been drilled out, I don't thing two size holes would work well at all - when the rivets expand they fill the hole - but not one that has two sized holes.
I remember that panel - did you ever replace it?
As I understand the gold is just a protective coating they put on to protect them in the bins - comes right off.
The one's I got (and yes they were 1/8) had that coating on them - came right off.
Ken J
1958 Overlander
Ken J is offline   Reply With Quote
Old 08-28-2008, 08:11 PM   #269
markdoane
Profile:  , Minnesota
Images: 59
I did a whole side of my Tradewind. I agree with Shari, you might be able to punch the tail out of some of the drilled out rivets, but you'll always end up with more then a few that need to be reamed out to 5/32". I used 5/32 for the whole side.
I didn't see any evidence of triangular holes. That only happens to me when I try to drill a large hole in sheet stock with too big a step between drill sizes. If you're just upsizing from 1/8 to 5/32 you won't have any triangularity.
The gold coating is just alodine; most of it rubbed off during the rivet setting. It certainly doesn't look like gold polka dots.
I perfectly happy with the end result. Only complaint is that the replacement panel is a lot more shiny than the surrounding panels.
Non-contributing deadbeat.
Old 08-28-2008, 09:56 PM   #270
65CV
Profile:  1965 17' Caravel
Southern , Connecticut
Read this too late
I read the 1/8 buck comments too late. I bucked the whole thing with 5/32 today. Looks great -- too good compared to the rest of the trailer.
Not only are there gold polka dots, but vulkem rings-around-the-collar.
Those will clean up easily tomorrow.
John
65CV is offline   Reply With Quote
Old 08-29-2008, 10:28 AM   #271
Ken J
Guess I got lucky or something - when I replaced the rivets all along the bottom of the trailer - I used 1/8" and they seemed to fill very well - that was 2 years ago or so and they are still there, no leaks.
Ken J.
1958 Overlander
Old 08-29-2008, 10:50 AM   #272
markdoane
Images: 59
Ken,
Where were you able to find 1/8" Brazier Head rivets? I though those are hard to locate.
Old 08-29-2008, 10:54 AM   #273
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Originally Posted by markdoane View Post
Ken,
Aircraft Spruce has them, but with alodine.
Airstream has them, colorless soft aluminum, by the barrels, avaible thru dealers.
If your in Jackson Center, you can buy them direct from Airstream.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Old 08-29-2008, 11:41 AM   #274
Ken J
Yup - I got mine from Aircraft Spruce....easy to find, once you know where to find them....
Kinda like instructions - they always make sense once you know how to do it....
Ken
1958 Overlander
Old 08-29-2008, 02:00 PM   #275
markdoane
Images: 59
I didn't see anything on there web site except the Universal and Countersunk rivets. Did you have to call them to get the Brazier Head rivets, and were they special order?
Old 08-29-2008, 02:01 PM   #276
markdoane
Images: 59
If you're OK with soft rivets, you can buy them by the truckload from Grainger. Not my cup of tea.
Old 08-29-2008, 04:02 PM   #277
Ken J
Gosh - that was a couple of years ago - don't remember if I got their catalog or on line. I get a couple of those guys mixed up - they are the one's in California - not the folks in Kansas City where I bought my Aluminum
Ken J.
1958 Overlander
Old 08-30-2008, 12:02 PM   #278
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
I don't see any AN455 (brazier) rivets at Aircraft Spruce. Only AN426 and An470.
I got mine from Jay-Cee sales.
Zep
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 09-11-2008, 04:16 PM   #279
atmouse
atmouse's Avatar
Belmont , New York
Hi! I ordered rivets - Universal Head, AD, 4-3, 4-4, 4-5 and 4-6's. I got them today. I noticed right away that the head size is alot smaller than what is on the Airstream now.
We went out and measured the heads and they are about 1/4' across. So what is that about? Did I order the wrong rivets?
And these are NOT Olympic rivets on the AS. They are solid rivets.
atmouse is offline   Reply With Quote
Old 09-11-2008, 05:13 PM   #280
markdoane
Images: 59
Here's the straight skinny:
The original rivets were 1/8" Brazier head rivets. Head diameter is .312"
You can replace with 5/32" Universal head rivets. Head diameter is .312". Head is just slightly more dome shaped than the Brazier head, hardly noticable. 1/8" Universal head is too small, as you discovered.
You can also replace with 5/32" Modified Brazier head rivets. Head is the same size as the regular Brazier head, but the stem is 5/32".
So I would suggest, that you drill them out to 5/32" and use the very easy to get Universal head rivet, or you can also use Olympic rivets which are also 5/32" stem size. If you're a perfectionist, use 5/32" Modified Brazier heads.
test
