Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 10-27-2005, 06:32 PM   #225
A-Merry-Can
Addicted to Aluminum
A-Merry-Can's Avatar
Profile:  1959 18' "Footer"
1962 19' Globetrotter
1964 24' Tradewind
Woodstock , Georgia
hey greg,
did you end up fabricating any window drip moldings? just curious, as that's coming up soon on my list of to-dos.
jp
8576 • • • • • • • •
there's always room for one more!
• • www.toolbox-design.com • •
A-Merry-Can is offline   Reply With Quote
Old 11-03-2005, 12:10 AM   #226
greg176
greg176's Avatar
Profile:  1961 26' Overlander
Gabriola Island , British Columbia
No I was able to repair my old drip caps enough to pass.I am held up now by the heavy rain.Trying to get lower rub rail on in front so I can close inner skin in front and start on dinette.
greg176 is offline   Reply With Quote
Old 11-03-2005, 01:27 PM   #227
Ken J
Profile:  1958 26' Overlander
Tijeras , New Mexico
You can still buy those drip moldings if you need them......
1958 Overlander
Ken J is offline   Reply With Quote
Old 11-06-2005, 04:58 PM   #228
A-Merry-Can
1964 24' Tradewind
Woodstock , Georgia
where? and are they decent looking? i've seen some that look like cheaply stamped metal. i'm going to have to come up with something soon for the rear window.
jp
Old 01-25-2006, 07:08 PM   #229
NorCal Bambi
NorCal Bambi's Avatar
Profile:  1963 16' Bambi
Yreka , California
Images: 21
Drip Moldings?
By drip moldings are you talking about the piece of metal over windows. See attached. If not, what is the item over the window in this picture? Were these a extra item or did they come on some trailers and not others? Are they still amiable and where can one get them?
Thanks Don
NorCal Bambi is offline   Reply With Quote
Old 01-25-2006, 11:03 PM   #230
C Johnson
C Johnson's Avatar
Profile:  1965 17' Caravel
Portland , Oregon
Images: 326
I have seen those drip caps at my local RV parts place in a variety of sizes.
Chris
Chris AIR # 7276 WBCCI # 7276
WBCCI Forum Save Wally Forum
Photos of Project 2k5 My Blog Chris' World
My Pictures
C Johnson is offline   Reply With Quote
Old 06-06-2006, 10:40 AM   #231
davidrylands
Profile:  1972 29' Ambassador
Waterton , Alberta Canada
Skin replacement
I need some help replacing a damaged section of exterior skin. I have some rib damage and don't know where to start. Any help would be appreciated.
davidrylands is offline   Reply With Quote
Old 06-06-2006, 12:07 PM   #232
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Post some photo's, so that the exact damage can be seen.
What you do, and how you do it depends on what's damaged.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 08-20-2006, 03:56 PM   #233
gsoter
Profile:  1986 27' Sovereign
Farmville , North Carolina
Skin Fitting
Hey Ken
Im new here, but my real job I am a structure mechanic on aircraft. There are alot of different ways to fit the new skin, but when I fit a new skin on a aircraft I usually fit in in place, mark all the holes I can, then use the old skin as a template to pick up the ones I could'nt. I do have hole finders I use if i have to, but be careful of oil canning.Make sure your new skin is laying as perfect as you can, if you miss drill a hole, stop and countersink both sides, one being smaller on one side, and plug it with a solid countersink rivet then sand the protruding parts of the rivet flush, dont try to stretch holes, and if you blow a hole out, go to the next size rivet which would be a 5/32 or 3/16's.
gsoter is offline   Reply With Quote
Old 12-18-2006, 03:54 PM   #234
robertsonmd
Profile:  1971 27' Overlander
Baton Rouge , Louisiana
Ken J,
I think this might help you get the holes right. Strap Duplicator (#40) - 12" working length & More Aviation Supplies - SkyGeek.com
Dave
robertsonmd is offline   Reply With Quote
Old 12-18-2006, 04:41 PM   #235
A-Merry-Can
1964 24' Tradewind
Woodstock , Georgia
i used something like that just recently, in fact. be sure you get the right size for your rivets. they come in a variety of sizes.
depending on which skin panel you are replacing, you might not need anything. for example, on my 62 trotter, i'm going to have to replace the 2 rear quarter skins, and all the edges except the bottom are overlapped with another skin. that has 2 advantages. firstly, you don't have to locate holes. when you slide it in under the other panels, just drill back through the rivet holes and your golden. secondly, since all the edges of the aluminum are covered with other panels, you don't need to worry about a perfectly clean edge. when i reskinned my 59, the only panels i had to shear to size were the 2 ends under the windows.
now i'm finishing up the door, and there's NO way to do a clean job here without a shear and a metal break.
post pics for sure. the more we can all see, the mor ewe can help ya... plus nobody likes to read a book with NO pics in it!
jp
Old 02-08-2007, 03:03 PM   #236
Pop Rivet
Pop Rivet's Avatar
Profile:  Salt Springs , Florida
Can someone tell me the average distance between the inner and outer skin?
Pop Rivet is offline   Reply With Quote
Old 02-08-2007, 03:26 PM   #237
Commercial Vendor
For trailers made with "Z" bows and all motorhomes, the distance between the inner and outer shell is 1 3/4 inches (1.750).
Inlandrv.com
800-8777311
Old 02-08-2007, 04:38 PM   #238
Pop Rivet
Pop Rivet's Avatar
Thanks Andy - Inland has been a friend to the forum for a long time. I value your expertice and envey Inland's postion for the resto explosion. Just remember us little guys
