Old 07-09-2010, 06:26 AM   #1
berickn's Avatar
1972 25' Tradewind
Bemidji , Minnesota
skin replacement
I have a 1972 25' tradewind that I just got the #10 body segment for. Thats the segment right above the front window in the center. Does anyone have any tips on which end to start with or etc. cutting? And is the replacement panels polishable? or any tips on matching the rest of camper is polished.
berickn is offline   Reply With Quote
Old 07-09-2010, 12:50 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Start drilling and clecoing from the middle working from one side to the other, up and down. Don't trim until you have to. It may be easier to remove the front window and frame before you start.
Old 07-09-2010, 08:18 PM   #3
berickn's Avatar
1972 25' Tradewind
Bemidji , Minnesota
front skin
drill the rivets and remove whole front window?
Old 07-09-2010, 09:12 PM   #4
Aerowood's Avatar
Arvada , Colorado
You are going to remove most of the top rivets anyway, so you will only have to remove the bottom row to have all the rivets out, and by removal you don't have to worry about trimming the skin to an exact fit right off the bat. The skin you want to replace sides in under the window frame. The sides of the frame are held on with a dovetailed slide that needs to be driven either up or down to remove. Do these first. This will also allow you to reseal the front window which has a tendency to leak.
The new skin should polish up the same as the old.
Old 07-11-2010, 09:25 PM   #5
berickn's Avatar
1972 25' Tradewind
Bemidji , Minnesota
skin
Thanks aerowood!
Skin replacement Ken J Ribs, Skins & Rivets 292 05-29-2015 09:47 PM
Skin replacement problem FreshAir Ribs, Skins & Rivets 2 02-09-2009 08:27 PM
Skin Replacement 68 Safari uwe Exterior Restoration Forum 27 06-08-2006 09:50 PM
skin replacement jlester Ribs, Skins & Rivets 9 01-11-2005 04:21 PM
Underbelly Skin Replacement Morning Dew Belly Pans & Banana Wraps 5 08-21-2003 09:12 AM
