Old 08-14-2016, 08:44 PM   #1
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Skin repair using an English Wheel
This is my third go around with fixing AS skins using an English Wheel. This is the biggest project to date: five of the exterior end cape (all the skins from the rear window up).
Here is a picture of a couple of the panels with damage, all five had similar problems:
We purchased the trailer knowing the rear end was damaged. The damage was not hail as was suggested but likely the trailer was backed into a tree. After which somebody tried to push the dents back out. There was very little frame damage, which I think tends to eliminate damage from a falling object.
The English wheel can shift the metal around with little change in the panel shape or size. As you can see four of the five panels have been reinstalled. The benefit of this method is the panels will be the same age and patina.
Here is the results from working with these over the last three days. The last skin still needs to be straightened and installed. There is still clear coat on some of the skins, once the Olympic rivets are completed then we will strip the top half of the trailer, polish and then apply coatings. I think we will add a roof coating.
sgschwend is offline   Reply With Quote
Old 08-14-2016, 09:14 PM   #2
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
Nice work! Love to see photos of you using the tool.
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 08-16-2016, 09:18 PM   #3
sgschwend's Avatar
1986 25' Sovereign
Images: 13
I will give it a try, vid might be better, it takes two of us to run the machine.
Old 08-16-2016, 11:22 PM   #4
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I have always been told that when aluminum was dented it stretched and could not be worked back to shape. Is your work proving that to not be the case, or is something else in play here?
Ken
Old 08-17-2016, 11:42 AM   #5
1973 31' Sovereign
Boise , Idaho
Have always wondered if an English Wheel would work on cleaning up the dents on the banana wrap of our '75 Globetrotter, could you provide some details on the technique you used to prevent stretching the aluminum any further.
Marcher is offline   Reply With Quote
Old 08-17-2016, 09:36 PM   #6
sgschwend's Avatar
1986 25' Sovereign
Images: 13
I did get a couple of pictures taken and will get them loaded tomorrow. To answer the question about size changing, for all practical purposes the skin size does not change. I have reinstalled four panels using the original holes, to locations that were not wheeled, such as all the outside edges and window framing. In the description of fixing a dent you will see a statement about the wheel area needing to push against the unwheel area around it so that it can move up. The unwheel area is still the original size, hence the wheeled area can locally expand and push against it.
I have completed repairs using annealing and without annealing. A simple dent would likely be able to fix without annealing. When you work the material you can tell if it is moving easily and therefore does not need to be annealed.
The next thing to know is that I am almost always using the finish setting which is a very light pressure hence very low shifting of the size of the part. If the part was the correct shape this setting would likely be the same as the aluminum thickness.
Folks that are experts, which I am not one of them, work their material and then the last step is to switch to a light pressure and run the part to finish it. I also use the largest radius anvil, which is least aggressive. The top wheel is flat, the bottom wheel is called the anvil and most machines come with a range of curves.
I have found that the easiest way to fix a skin is to address a small area at a time, find an area that needs fixing and roll that part. Move around the skin fixing each problem spot. This is not a common method, but again I am not making a compound curve part I am just returning certain areas back to the correct curve.
I have also found it is better to move all the high spots down first (which means run the part upside down), then turn the part right side up and raise the low spot. It does go amazingly quickly.
Image moving a high spot down:
To fix a dent: Imagine a six inch round low spot, dished down, a typical type of dent. This defect is much smaller than the skin and there is lots of skin around it to maintain the total skin shape, fixing this will not change the size of the skin. The surrounding material is what the wheeled material will push against to allow it to rise into place. You would put the part in the wheel right side up, with a low setting you would roll back and forth starting from one edge and moving 1/2" over after each pass stopping at the other side of the dish. The material will move up where it was wheeled.
Old 08-17-2016, 09:55 PM   #7
Ag&Au's Avatar
I'm thinking you should go into business fixing dented Airstreams.
Ken
Old 08-18-2016, 10:45 PM   #8
sgschwend's Avatar
1986 25' Sovereign
Images: 13
Here is a short video (52s) of removing two places where the skin is above the desired plane. Running the part upside down over the "high spots" will shift them lower.
http://vid212.photobucket.com/albums...psqzxn4ii3.mp4
Old 08-21-2016, 06:01 PM   #9
sgschwend's Avatar
1986 25' Sovereign
Images: 13
Well this project has taken three weekend to get the five skins in the back removed, straighten, and re-installed. I purchased a used Pasar Amprobe Leak detector, and tested the new skin assemblies and everything passed. For added leak prevention I installed the skins with AS seam sealant between the overlapping skins, and then on the inside spray undercoating.
There is plenty left to do but those tasks should be easier to do. The next steps are: shaving of the rivets, the painting of the roof, stripping of the belt line up of clear coat and restoring the aluminum then new clear coat, removing the blue tape, and lastly return the interior.
Here is a picture of the rear assembled, the rear awning is off to support the roof painting which will included the center top skin front and back.
Old 08-21-2016, 06:39 PM   #10
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
What make is your English Wheel?
Old 08-23-2016, 10:22 PM   #11
sgschwend's Avatar
1986 25' Sovereign
Images: 13
It is a China made copy of a Baileigh design. It has a 28" throat. Taking dents out uses very low pressure so I would think just about any wheel would work. I picked it up on that International online auction site. I offered $100 less they gave a 50 bucks discount.
I did measure the wheel spin accuracy and found it to be good, which is the measurement of the wheel roundness and axle center accuracy. If the wheel was inaccurate the pressure would modulate.
http://www.baileigh.com/english-whee...FQtqfgodrOwBUw
Pros and Cons
Cons:
you need to remove the skin, and strip it,
you may need to refinish the outside, in my case the upper three need refinishing the two side one just need some clear touch-up work.
need to install it, however the holes will match up so it goes fast.
Pros:
easy to remove dents,
metal is the same vintage as the trailer,
low cost,
can make patches to match any trailer curves,
with the annealing step you can redo a repair,
How about time:
Removing, striping, fixing, installing. I have heard one shop says they charge 6 hours per skin (they don't strip or fix), but they do need to drill.
For me I could easily do the above process in 6 hours per skin.
In this project I remove the 5 rear skins above the belt line and also the rear window. The window removal took three time the work than to remove a skin. The wheel time was nearly the same for any of the five skins.
In summary, drilling out the rivets 1 hour, breaking the inside bond 30 minute, stripping 2 hours, wheeling 30 minutes, installation 1.5 hours: total 5.5 hours.
Old 08-26-2016, 03:28 PM   #12
Aerowood's Avatar
Arvada , Colorado
I tried using the HF version and it was junk, the lower adjusting screw assembly and roller clevis had to much slop and it would not stay in adjustment. I have looked at the type you have and was curious as to it's quality. I had the opportunity to use a high quality cast iron unit a few years ago at Cascade Aerospace in Abbottsford BC, and it was an absolute joy to use.
Old 08-26-2016, 05:23 PM   #13
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
very interesting to watch the video. Cool stuff
1966 Overlander
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
Our AIRSTREAM and TIN CAN TOURIST Rallys
Old 08-26-2016, 06:33 PM   #14
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Ken
You can get some dents out all of the time. You can get some dents out some of the time. But you can't get all dents out all of the time.
Never have been able to completely get out a dent with a crease, but have been able to make it look better.
Don't know how an english wheel will work on a crease.
Anyone know English wheel metal fab in Bay Area CA twolanehwy Ribs, Skins & Rivets 8 05-17-2016 07:44 AM
English Wheel douglasbury Ribs, Skins & Rivets 10 11-25-2015 08:04 PM
Can these dents be worked out on an English Wheel? gronlampa Ribs, Skins & Rivets 12 09-07-2015 12:50 PM
$12 English Wheel, for the Bananas Globestream Belly Pans & Banana Wraps 10 06-04-2012 04:43 PM
English Wheel Users? ALANSD Ribs, Skins & Rivets 12 03-04-2004 08:26 PM
