Old 09-16-2014, 11:48 PM   #1
Mantua , Ohio
Skin gauge/thickness on what years?
I have a 61'. Is there a document available that confirms panel/skin thicknesses on what years?
From what I am reading, at some point they went from .100 to .120? Is this true? What year was that?
Any info would be greatly appreciated.
Studioman is offline   Reply With Quote
Old 09-17-2014, 02:11 AM   #2
Wrong.
In 61 to about 2000, all the shell metal was .032.
Then the lower sheet only was increased to .040.
The underbelly is even less.
Old 09-17-2014, 03:15 AM   #3
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
The skin thickness on your 61 is .032". No Airstream has .100" or .120".
Colin
Colin H is offline   Reply With Quote
Old 09-17-2014, 05:46 PM   #4
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
And if you're replacing panels make darn sure you get the right alloy. I didn't the 1st time out, very expensive mistake!
putback is offline   Reply With Quote
Old 09-17-2014, 05:59 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I found this post #2060 by r carl very interesting. I found it in the "corrosion on new Airstreams" thread.
"In the 1960's the aluminum was Alcoa‐Aluminum Alclad sheet 2024‐T3 .032
In 1969‐Beatrice Foods questioned cost of material. They started experimenting with 6061-T6,
it was still heat treatable and less expensive than 2024.
1972 switched to 6061‐T6 .032 1977/78 Alcoa 3004‐H291 Brite Panels .032
1983 Alcoa 3003‐H18 .032 Controlled mill finish
1986 Alcoa 3005‐H18 .032 Controlled mill finish
1993 Switched to Alumax 3005‐H18 Controlled mill finish W/ Precoat side and window sheet .040
1994 Trailer shape changed –material remained same thickness increased to .040 to help carry the weight of shell change.
1998 ‐200….Alcoa Bright Versatrim leveled sheet 3004‐H18 side and window sheet .040 3003 O Temper .040 thicknesses with special coating from Alcoa for the segments used to make the front and rear end caps. This material is stretch formed at Airstream."
It is a good history of the aluminums Airstream has used through the years.
David
Skin Thickness - Exterior lisaslists20 Ribs, Skins & Rivets 3 07-06-2014 01:10 PM
Thickness of the door skin is 0.040 and not 0.032"? ronstory Ribs, Skins & Rivets 11 09-30-2008 01:10 PM
Beatrice Years - Years and Models to Avoid? AndyPenny Buyer Guidelines 7 10-15-2007 11:04 AM
Type and thickness of exterior skin? reece1107 Ribs, Skins & Rivets 6 02-19-2006 05:23 PM
Skin thickness Steve St. J Ribs, Skins & Rivets 1 09-23-2003 10:57 AM
