Old 10-29-2013, 12:15 AM   #1
1972 21' Globetrotter
Wylie , Texas
skin flip-flop
After removing skins in my rear bathroom area, i placed them in sequence on the ground. I noticed they could be reversed, switched to the opposite side, placing the zolatone toward the outer walls. I like the look of the white paint used on the inside of the panels without the texture. I may give it another coat and then do the swap with the other side upon replacement. Has anyone tried this? This could also potentially provide a slight thermal break (if you're into that sort of thing).
rippie is offline   Reply With Quote
Old 10-29-2013, 04:33 AM   #2
Baltimore , Maryland
You could also get new aluminum and paint it. Then you wouldn't have a bunch of holes that are reversed of where they used to be. They may look the same, but they are not. The holes were all drilled by hand and nothing is going to line up.
