Old 07-23-2013, 04:39 PM   #1
retrocar66's Avatar
1967 24' Tradewind
Greenville , North Carolina
skin damage question
I have a 1967 Tradewind that I've had about 2 weeks. It's been sitting in the driveway while I get it ready to camp. The only time I've moved it, since it was towed to my driveway and dropped off, is to pull it into the street once to do some hitch leveling.
The other morning I noticed this crease in the skin over the starboard side mid-trailer window. The crease is about a foot long and looks like a scratch, like someone took the edge of a 2x4 and dragged it along the skin. It looks like someone folded the aluminum and then tried to straighten it back out.
I am positive I haven't hit the trailer on anything - it has scarcely moved. And this scratch/crease is new, no question. No way I would have missed it when inspecting the trailer before purchasing.
So... any ideas what could cause this? Is this stress related somehow? Should I assume vandalism (seems unlikely given our neighborhood, but anything is possible I suppose.)
I'm posting 2 photos, one is a close-up of the crease, the other is from a few feet away so you can see where it's located along the trailer. It's about 2/3rds of the way back, right over the window.
ID:	191539   Click image for larger version
retrocar66 is offline   Reply With Quote
Old 07-23-2013, 06:24 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
A tree or shrubbery branch scratch? What you think is a small minor branch or bush will do that type damage.
Old 07-23-2013, 07:37 PM   #3
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
Rutherford Co. , North Carolina
it looks awful high to be vandalism. if a vandal wanted to mess up your trailer, why do it there? why not scratch up the side, like when a car gets keyed? i've had our 57 for 3 years and just noticed a scratch i never saw before. you're sure it's new?
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 07-23-2013, 08:00 PM   #4
retrocar66's Avatar
1967 24' Tradewind
Yeah I have photos from the delivery last week so I'm sure it's new. This 67 is miraculously free of dents, except for a couple of knee-prints in the rear end-cap, so it's very noticeable when a new one shows up.
Old 07-23-2013, 09:22 PM   #5
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Does it seem to get better or worse in the direct sun light? The metal can expand and contract as it heats and cools.
Silverflames is offline   Reply With Quote
Old 07-24-2013, 10:10 AM   #6
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Looks like something fell or leaned against your trailer to get a crease like that. Have you put a ladder against it at any point?
Old 07-25-2013, 11:55 AM   #7
retrocar66's Avatar
1967 24' Tradewind
more info
Definitely have not leaned anything on the trailer.
It doesn't change in the sun/shade. It's been sitting in the same spot for almost two weeks, so it gets sun for part of the day.
I'm mystified by this...
Old 07-25-2013, 12:08 PM   #8
Obviously, something hit the trailer perhaps like a small board.
That metal is "tempered stress relieved".
Simply expose that area to as much sun as possible. It make take several months, but the daily temperature change most likely will make most of that dent disappear, except for the crease.
The same thing happens when that metal receives hail damage. In time, most of it will disappear.
Old 07-25-2013, 12:17 PM   #9
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Exclamation Not to be the bearer of bad news, but...
Is that crease in the same area as the perforation you mention here? If so, it could be caused by a broken frame member or floor rot which has caused separation of the shell to the frame which causes the deflection.
But it looks to me to be more like a awning pole hit it & scraped up the side...deflection crinkles look more like "oil canning" than dents/scrapes and aren't typically directly over a window like that.
Shari
Old 07-25-2013, 12:29 PM   #10
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
If you decide to look under the belly pan to investigate the tear you need to get some wide flange rivets (easy to replace) vintage trailer supply carries them. Good luck.
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 07-25-2013, 12:30 PM   #11
1969 29' Ambassador
Did you open and close the awning recently?
Old 07-26-2013, 12:34 AM   #12
retrocar66's Avatar
1967 24' Tradewind
The awning has been closed since the trailer was delivered. That crease showed up afterward.
This crease is on the opposite side of the trailer from where the skin perforation is (in my other post.) This crease is top right, the perforation is lower left side.
It's sitting in the driveway for now and getting plenty of sun (NC summer) so hopefully that will take some of it out.
