Old 01-13-2015, 04:08 PM   #1
1965 22' Safari
Asheville , North Carolina
Skin Corrosion Repair Advice
Hello,
New trailer owner here...."65 Safari with 3 spots similar to this. Can I cut this out and rivet a larger patch over the void. Obviously want to fix it right once and for all. Thanks everyone!
jjkitt is offline   Reply With Quote
Old 01-13-2015, 05:20 PM   #2
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Why cut it out - just cover it up.
I would run the patch all the way to the wheel well - one less 'edge' - would look less like a patch.
Silver Hawk is offline   Reply With Quote
Old 01-13-2015, 05:23 PM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Agreed. Don't cut out the old section, just make a large patch that blends in as best as you can.
Bob Martel
WBCCI# 5766
Old 01-13-2015, 05:34 PM   #4
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
Jj kit, you will need to fix the corrosion cause 1st then repair or cover up.
I have this on my 54 Cruiser. Mine is on the belly pan panel which will be replaced anyway with my shell off resto.
Ensure it is corrosion or wear. Mine looks more like wear due to failure of the bond of the panels and the floor in the area. And some corrosion.
Either way, the aluminum is touching the outrigger which is where the corrosion is occurring and the wear due to movement.
Again, resolve the issue before covering it up. Also, check the structure between the floor and exterior panel.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 01-13-2015, 05:59 PM   #5
1965 22' Safari
Thanks. I read somewhere on here that corrosion is like cancer and must be dealt with or else if simply patched over it will continue to corrode. Obviously it would be simple to cut out a patch and rivet it on but I do not want further problems. Should the rib be grinded back to prevent further degradation of the skin?
Old 01-14-2015, 07:50 PM   #6
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
In the Navy, to preserve and protect, we used a Zinc Chromate primer on my last Spruance Class Destroyer. Everything from the main deck up is (was) aluminum, and that as a basecoat over bare Al prevented all kinds of corrosion from the elements. There are other primers and coatings that you could use, but the Zinc Chromate works best over the long haul. Any place that sells marine coatings should be able to get it for you. As far as a patch or repair, that will be your aesthetic choice. Hope it works out like you want it to.
NavyCorpsman is offline   Reply With Quote
Old 01-15-2015, 05:29 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Same thing happened to our 63 Safari, caused by a cracked outrigger, it had to be straightened, welded & primed with Z-chromate.
Galvanic corrosion
Exterior Corrosion Repair PaulAir Clearcoat, Exterior Paint & Trim 27 05-24-2018 06:44 PM
Skin & Corrosion Updates silverhound Clearcoat, Exterior Paint & Trim 39 10-11-2012 11:01 AM
Skin Corrosion - Another Road Another Road Ribs, Skins & Rivets 5 09-11-2012 06:28 PM
Inside corrosion of outside skin Breadbug Ribs, Skins & Rivets 4 02-01-2011 10:37 AM
Emergency skin corrosion info please! yochanan Ribs, Skins & Rivets 2 04-29-2010 03:30 PM
