05-13-2015, 10:23 PM
1972 31' Sovereign
Racine
, Wisconsin
Side trim
Does anybody have this piece that I could buy?
1972 Airstream International Land Yacht Sovereign
10-23-2016, 12:45 PM
1964 22' Safari
1968 26' Overlander
Beaver County
, Pennsylvania
I recognize this is an old post, but did you ever find a source for this side trim? I'm looking for a similar piece about 48" long.
Roy
10-23-2016, 01:23 PM
1973 31' Excella 500
Vicksburg
, Mississippi
10-24-2016, 07:37 AM
1964 22' Safari
1968 26' Overlander
Beaver County
, Pennsylvania
Al,
Thanks for the response. I saw these during my ongoing search, but they're not quite the right cross section. The trim I'm after is 1" wide extruded with two "peaked" ridges about 5/8" apart. It appears to have been used in the late 60's and early 70's. As I indicated, I'm going to need a piece about 48" long, but I could piece together some straight pieces if needed.
With a little luck, I'll be taking the bad section off soon and can post a couple of better photos.
I'll keep looking but appreciate the help.
Roy
10-24-2016, 07:45 AM
1964 22' Safari
1968 26' Overlander
Beaver County
, Pennsylvania
Al,
I enlarged the original post and noticed that some of the trim on mrrealtor's trailer was replaced from original. Now, I'm thinking, if I can't find the original trim, I could replace the trim on one entire side with the second one you posted.
Thanks again,
Roy
10-25-2016, 08:07 AM
1972 31' Sovereign
Racine
, Wisconsin
Yea, I know that this trim is sold by some online retailers but its sold in 8' or 16' lengths. I would just hate to buy that much only needing about 15" of it.
11-29-2016, 02:30 PM
1987 29' Sovereign
Huntsville
Have you contacted Camper Repair ( http://www.camperrepaircenter.com)? They have a ware house full of older parts.
01-16-2017, 09:48 PM
1974 27' Overlander
Salt Spring Island
, British Columbia
Look for an AC unit
Hi,
I also need to replace some of this trim on my 1974 Overlander. I just pulled down the original AC unit and it has a band of the same trim strip around it. I'm ditching the AC unit so I'm just re-purposing that strip to repair the missing section.
Thought I'd mention it in case you can find an old AC unit for cheap/free. There was about 9 feet of it up there!
Cheers
01-17-2017, 05:39 AM
1964 22' Safari
1968 26' Overlander
Beaver County
, Pennsylvania
canadianair,
Thanks for the tip. I'm still searching and will also watch for old AC units.
Roy
01-20-2017, 03:42 PM
1972 31' Sovereign
Racine
, Wisconsin
Originally Posted by canadianair
Hi,
Cheers
Thanks for the tip, although when I replaced my '72 air conditioner there was not any trim
01-31-2017, 05:39 PM
1972 27' Overlander
Denver
I would not ditch that bay breeze ac. It's rebuildable and reliable also loud and ugly.
Lucky Dave, Denver NC
