Old 05-13-2015, 10:23 PM   #1
mrrealtor's Avatar
1972 31' Sovereign
Racine , Wisconsin
Side trim
Name:	ImageUploadedByAirstream Forums1431577389.725538.jpg
ID:	238392 Does anybody have this piece that I could buy?
1972 Airstream International Land Yacht Sovereign
mrrealtor is offline   Reply With Quote
Old 10-23-2016, 12:45 PM   #2
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
I recognize this is an old post, but did you ever find a source for this side trim? I'm looking for a similar piece about 48" long.
Roy
64airstream is offline   Reply With Quote
Old 10-23-2016, 12:48 PM   #3
Al Boondy's Avatar
1973 31' Excella 500
Vicksburg , Mississippi
Roy I think that this is what you are looking for...
http://airstreamsupply.com/Parts-Rep...y-1970s-106911
Al Boondy is offline   Reply With Quote
Old 10-23-2016, 01:23 PM   #4
Al Boondy's Avatar
Or maybe this one...
http://airstreamsupply.com/New-Airst...-1-4-106911-01
First link is lower moulding
Old 10-24-2016, 07:37 AM   #5
1964 22' Safari
1968 26' Overlander
Al,
Thanks for the response. I saw these during my ongoing search, but they're not quite the right cross section. The trim I'm after is 1" wide extruded with two "peaked" ridges about 5/8" apart. It appears to have been used in the late 60's and early 70's. As I indicated, I'm going to need a piece about 48" long, but I could piece together some straight pieces if needed.
With a little luck, I'll be taking the bad section off soon and can post a couple of better photos.
I'll keep looking but appreciate the help.
Roy
Old 10-24-2016, 07:45 AM   #6
1964 22' Safari
1968 26' Overlander
Al,
I enlarged the original post and noticed that some of the trim on mrrealtor's trailer was replaced from original. Now, I'm thinking, if I can't find the original trim, I could replace the trim on one entire side with the second one you posted.
Thanks again,
Roy
Old 10-25-2016, 08:07 AM   #7
mrrealtor's Avatar
1972 31' Sovereign
Racine , Wisconsin
Yea, I know that this trim is sold by some online retailers but its sold in 8' or 16' lengths. I would just hate to buy that much only needing about 15" of it.
Old 11-29-2016, 02:30 PM   #8
Airstream87's Avatar
1987 29' Sovereign
Huntsville , Alabama
Have you contacted Camper Repair (http://www.camperrepaircenter.com)? They have a ware house full of older parts.
Airstream87 is offline   Reply With Quote
Old 01-16-2017, 09:48 PM   #9
1974 27' Overlander
Salt Spring Island , British Columbia
Look for an AC unit
Hi,
I also need to replace some of this trim on my 1974 Overlander. I just pulled down the original AC unit and it has a band of the same trim strip around it. I'm ditching the AC unit so I'm just re-purposing that strip to repair the missing section.
Thought I'd mention it in case you can find an old AC unit for cheap/free. There was about 9 feet of it up there!
Cheers
canadianair is offline   Reply With Quote
Old 01-17-2017, 05:39 AM   #10
1964 22' Safari
1968 26' Overlander
canadianair,
Thanks for the tip. I'm still searching and will also watch for old AC units.
Roy
Old 01-20-2017, 03:42 PM   #11
mrrealtor's Avatar
1972 31' Sovereign
Racine , Wisconsin
Originally Posted by canadianair View Post
Hi,
Cheers
Thanks for the tip, although when I replaced my '72 air conditioner there was not any trim
Old 01-31-2017, 05:39 PM   #12
1972 27' Overlander
Denver , North Carolina
I would not ditch that bay breeze ac. It's rebuildable and reliable also loud and ugly.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Side window glass rubber trim '09 Interstate Wisconsinden Sprinter and B-van Forum 1 10-24-2012 08:10 AM
Tambour trim and trim Big C General Repair Forum 6 08-14-2012 08:01 PM
Classic Motorhome side moulding trim.. Keyair Classic Motorhomes 6 12-15-2010 08:02 PM
Weight Distribution, side to side JimC Towing, Tow Vehicles & Hitches 8 08-13-2003 03:19 PM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 10:29 AM
