Old 05-13-2010, 07:08 PM   #1
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
Should I feel bad?
Tomorrow Im picking up a 1963 Safari that is currently a shell-off restoration project. When the shell was removed the C channel was taken OFF the shell and mounted to the 'new' floor. The shell got torqued a bit in its current position. I was told that all the interior lower panels are included. It looks as if none of the smaller access doors are present. All the glass is good. Jalousie windows look and work great. Exterior panels look good for hte most part, but a ppo painted the trailer a matte finish silver! Some of that has come off. Should I feel bad about parting this out? pics to hopefully be posted tomorrow!
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
aircooled4 is offline   Reply With Quote
Old 05-13-2010, 07:15 PM   #2
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
I wouldn't feel bad. Wait and lets see your photographs!
https://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 05-13-2010, 07:57 PM   #3
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
Heres a pic...
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
Old 05-14-2010, 05:11 AM   #4
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
Let me know if any of you need anything off this...:-(
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
Old 05-14-2010, 06:23 AM   #5
ts8501's Avatar
2022 25' International
Savage , Minnesota
I believe you actually have a '64 Safari here. I count 5 end cap panels. '63 had 7 end cap panels. The "mid ships" curbside door also gives it away as a '64. If I am right, your side windows (not the Jalousie's) are unique to '64 California built coaches as well. I started a thread about '64 Mystery Side Windows linked here. Just to confirm, see if you can pull the serial number from under the Curbside Front Jalousie. My guess is your trailer is built in '63, but it is a '64 model.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 05-15-2010, 08:20 PM   #6
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
also had the below the floor tanks which was new in 64....
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 05-15-2010, 08:31 PM   #7
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Are you actually parting this out? If so, I could use some windows.
Uwe
www.area63productions.com
Old 07-03-2010, 06:49 AM   #8
1960 24' Tradewind
Janesville , Iowa
Hey Jay,
Thanks for the door. A couple of things you'll want to know. Under the matte silver is a lime green paint, and under that the skin has been sanded with a random orbit sander with 100 grit paper I assume to give the surface grip? Not what we expected to see under all that paint but a sanded door is better then no door. Does anyone have any ideas on how to buff out this much surface damage or should I just paint it lime green again?
whatsherface is offline   Reply With Quote
Old 07-03-2010, 07:19 AM   #9
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
There is the coarse polishing stuff you can get from here Nuvite Polish
You could also try a rubbing compound. But those must be some pretty deep scratches. with some nice swirl marks. green isn't all that bad. "well thats what you can keep telling yourself" "Green?" What were they thinking?
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Feel bad not ripping trailer apart! Trophycare 1959-69 Tradewind 18 10-14-2009 08:03 PM
Feel the Fear and Do It Anyway Wardinbb 1959-69 Tradewind 32 10-19-2008 04:48 PM
how would you feel if you remcolent Off Topic Forum 5 09-05-2006 10:15 PM
I feel like I'm living in Ground Zero jcanavera Our Community 14 04-10-2006 07:02 AM
I feel like such an Idiot.... Pick Steps 3 10-24-2002 12:59 AM
