Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 04-14-2012, 10:34 AM   #1
ddruker's Avatar
1999 27' Safari
Palo Alto , California
Should I buy or should I run away
I've been looking locally for an airstream for about six months now, and found a 31 foot 1977 International Sovereign that I'm thinking about pulling the trigger on.
The good news is that the frame is solid, the rear is not loose or drooping and there are no leaks or floor rot. I'm confident of my skills to restore the interior.
The bad news is that some of the skin damage scares me and I've got no experience at all (yet) dealing with body repairs.
Here are pictures of the two areas of concern. This is all on the drivers side rear of the trailer - one problem area is a whole bunch of dent craters on the corner of the roof, the other is a roughly 10 foot long long horizontal dent and scratch mid-way up the side wall.
Question is about the cost and difficulty of repairing or at least minimizing this damage. Would greatly appreciate your guidance on what I'm looking at here, and whether this body damage should cause me to run away from this otherwise decent trailer. I'm not looking to make it perfect, but I would want to improve it a lot over the way it is now.
From reading here, it looks like the dents on the corner should be easier to repair than the horizontal scratch. But that's why I'm asking the experts.
ID:	155724   Click image for larger version
ddruker is offline   Reply With Quote
Old 04-14-2012, 10:52 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Welcome to the Forums. We're glad to have you with us.
That's a pretty nice looking trailer. If the mechanicals are good and the price is right, you probably are getting a good trailer. The end cap may need to be replaced. The scratches, I could live with. We have similar scratches on our Lucy from her extensive use. If you use the Airstream , it is going to get road scars. The only perfect Airstreams are yard queens.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 04-14-2012, 11:10 AM   #3
Ball park cost if you had a dealer do it, would be about $ 4500.00.
But, it's not difficult to replace that metal, once you know how.
On the other hand, that trailer would always stand out from the others, so that you would know exactly which one is yours.
Then really, those dents and gouges don't hurt a thing.
If the price is right, go for it.
Only other thing, is make sure you check out the axles and make sure they are still serviceable. If not, then the selling price further drops.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 04-14-2012, 11:18 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
You will probably be able to reduce the dents on the end cap with a tool like "Pops a Dent" or "Ding King". The long crease is another matter.
Old 04-14-2012, 12:04 PM   #5
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
A trick I heard of on the VAP(vintage airstream podcast) to reduce the dents is to use a hot glue gun and glue an elevator bolt to the center of the dent and pull it out then heat the glue back up to get the bolt off. No holes needed this way. Otherwise a trailer that has any use is going to have some memories built in.
Good luck with your purchase!
It's not worth doing if you're not having fun.
https://tinman54.blogspot.com/
https://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 04-14-2012, 12:18 PM   #6
kennyp315's Avatar
1965 20' Globetrotter
Woodland Hills , California
Images: 8
Those scratches and dings are not much to worry about. I would be more concerned about the length of the trailer. Unless you have a big family and need that much space, a shorter trailer will allow you to get in more campsites. I wouldn't bother with anything longer than 25'. Just my two cents.
kennyp315 is offline   Reply With Quote
Old 04-14-2012, 01:40 PM   #7
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
You might have luck getting the end-cap dents to look 'acceptable' without replacing that panel. There is nothing you can do with the scratch/crease that is going to make it look any better. It depends if you are happy with sealed and functional, or if you want it to look like new. Unfortunately, you have to be very cautious with Airstreams to prevent all kinds of nicks and dents from causing distracting flaws.
As I've just taken my Airstream to a dealer for a new panel, they did a complete walk around and marked down every little thing they could find - as they put it "If it's an Airstream, repair means replace" and they don't want to be on the hook for alleged lot damage.
Friday is offline   Reply With Quote
Old 04-14-2012, 02:17 PM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
Essentially this technique is the backyard version of the Ding King tool. I would use a piece of 2x2 wood.
As far as the long crease, you could get a piece of aluminum trim to match the others. Most people, except us experts, would not know it doesn't belong there.
Old 04-14-2012, 02:34 PM   #9
Globie64's Avatar
1964 19' Globetrotter
South Kingstown , Rhode Island
Images: 18
I see the dents several ways: you could live with it as patina, especially if the rest of the trailer is in good shape and the price is right; you could try and pull out (someone even mentioned using a toilet plunger or other suction device) the dents on the end caps, or have it replaced. After 10 years of working on ours, a usable trailer right off with some character sounds pretty good. The size is kind of daunting, but then you'd tailor where you drive and camp to the size of the rig. We're at the limit at 19' at state parks here.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 04-14-2012, 02:38 PM   #10
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
All bumps and dings have a story,, just make it yours and add a few of your own... We had a 40th b-day party for our AS April 7th,, Most of our dings are on the bottom edges..
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 04-14-2012, 02:48 PM   #11
Lumatic's Avatar
1993 34' Excella
Images: 16
I had a 31 now have a 25. A 31 does limit campsites somewhat but I usually was able to find one,
Old 04-14-2012, 03:04 PM   #12
Cracker's Avatar
Pittsfield , Maine
IMHO the only real concern about length is whether or not you have the tow vehicle to pull it and the yard/driveway space to park it!
Cracker
Cracker is offline   Reply With Quote
Old 04-14-2012, 04:29 PM   #13
Roblin , MB.
Hi,
You might consider getting a length of trim the same as the one below the scrape and work vertical strips down to attach to the lower horizontal trim. I notice in your picture the vinyl insert has been removed from the 2 horizontal trim pieces. This vinyl insert is available at Inland RV Centre. A person could only look at one side of your A/S at a time and nobody will ever notice the difference. This would be a relatively inexpensive fix when completed.
As far as the endcaps are concerned - can you see much of the damage if you are looking at it from ground level?? Or as Sodbust has mentioned above make up a very interesting story as to how the damage occured and stick to it.
I remember an elderly farmer from here and if someone was pointing some damage out to him his response was " a blind man would love to see that"!!
I wouldn't run - I'd buy - it will all work out. Our '72 International 31' we're restoring has a small dent in the rear end cap and I notice it occasionally and just think to myself that the PO must have been some p'd off when he backed into a tree limb!!
Good luck and don't be concerned about the 31' length.
nairnchyz is offline   Reply With Quote
Old 04-14-2012, 09:15 PM   #14
Splitrock's Avatar
Sioux Falls , South Dakota
All I'm buying when I buy an old Airstream is the aluminum body. If that's not right, then it's either too big of a project, too expensive, or it's a parts trailer. There are trailers for sale with all good bodies. I'll pass on this one.
Old 04-14-2012, 09:51 PM   #15
Eric H's Avatar
1974 23' Safari
1947 25' Spartan , Manor
I would agree with this for me personally, I would rather be the one to put the dents in my trailer:-). But that's not to say it would be the same for you. If all you see are the dents when you look at it then passing on it might be best. If you can ignore them then it might be right. It does seem a bit strange to buy a trailer and then spend close to twice as much to fix it as what a non dented trailer might cost....
When you say the frame is solid; how did you determine this? Are some of the wraps and belly pan missing so you can see it? Or did the owner tell you this? Hard to know until you get under there.....
The price on this should be very reasonable with the size and the dents (once again, not to say this is bad). Good luck!
Eric H is offline   Reply With Quote
Old 04-15-2012, 09:49 AM   #16
ddruker's Avatar
1999 27' Safari
Thanks everyone for the tremendous number of replies and the fantastic advice.
This was extremely helpful. It's fascinating how personal all of this is and there is clearly no hard right or wrong answer.
As to some of the questions posed:
I've focused on 25 feet and up in my search because I'd like to be able to accommodate my wife, kids and dog comfortably. My kids and I love to go camping, by my wife just won't do a tent - so this project is in part an attempt to draw my wife into outdoor family activities. I also have hugely fond memories of family car vacations all over the US when I was growing up - and want to offer the same experience to my kids.
I understand the length restrictions - we go to Yosemite a lot and they allow trailers up to 35 feet, but we'd be banned from Pfeiffer Big Sur which we also love but only allows up to 27 feet.
When I said frame is solid - I did a visual inspection of everything I could see without removing the belly pan and saw minimal to no surface rust anywhere the frame is exposed. There is no sign of droop on the rear of the trailer and I jumped up and down on the rear bumper and saw no flexing or sign of separation. The subfloor is exposed in the trailer and I saw no evidence of water damage anywhere.
All this said, I'm still on the fence based on the feedback here. And on the fence means pass I think on a project this big unless I can get the seller to really drop the price. She started out at $13k for this trailer last summer, and the asking price has been going down every month since and now stands at $5k. I'm thinking more like $2,500... There's another one that just showed up on Craigslist where the body looks to be in better shape and I think I'll go visit that one next week - it seems like about once a month a new trailer comes on the market here in the Bay Area.
Again thanks for the amazing replies - I'm just blown away.
Old 04-15-2012, 10:35 AM   #17
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Another factor to consider... it seems to me that vintage Airstreams (and just about everything else old and cool) commands higher prices in California, vs. everyplace else.
Could be the better weather... the symbolic link to movie stars and Ray-Bans... who knows.
I put this theory to the test when selling our GlobeTrotter last year. After weeks of getting little to no response on Chicago's craigslist and eBay with a Chicago location, I added the option of delivery to California. Poof, our GT sold almost immediately - and for 50% more than the previous high bid. It now happily resides in Santa Cruz.
My roundabout point is that if you're willing to look a little further afield than the west coast, you may find you get a lot more for your money. You certainly don't need to settle for creases and dents in a 70's trailer, which are still quite plentiful.
Lastly, I'll stress that we've found our trailers in Washington, South Carolina and Michigan, and getting it home has always been a hugely enjoyable part of the adventure.
bredlo is offline   Reply With Quote
