Old 01-27-2004, 10:04 AM   #1
nevisstudio's Avatar
Images: 8
shell removal...
hello all....
i need some insight and things to look/look out for...
im going to lift the body off of he frame and need to know if my steps are correct..
-remove rivits/panels around the bottom of the inside of the trailer
-remove rivits around the outside of trailer...do i have to do the entire belly or can leave the belly seam intact...
-locate bolts that hold shell onto frame...will this b obvious cause i cant find any photos that show where these are..
-lift off shell.....i willhave a bunch of friends over to help lift it offf...how many people do u think it will take to lift it off..will it b heavy...
i think thats it....yes or no....
thanks
rich
nevisstudio is offline   Reply With Quote
Old 01-27-2004, 10:33 AM   #2
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Hey Rich-
Here's what I did when considering taking the body off the frame. I went to William Henshall's photo album here:
http://www.airstreamphotos.com/photo...=500&password=
and then I sorted the phots by: Sort by Latest
Then went to page 15, the beginning. He's posted detailed photos of each step, and it's a great resource. Now, I haven't actually attacked the project yet, so I don't know if he's leaving anything out or if there are differences, but I've taken all the photos and his comments and put them into a text document that I can print out and have near me when I'm doing mine this spring. At that point I'll also videotape most of the steps and burn them to DVD to have a record of how all this is done.
Have fun!
bredlo is offline   Reply With Quote
Old 01-27-2004, 11:08 AM   #3
Images: 59
Shell removal
You have the basic steps right. A few ideas:
1. Remove the entire lower interior panels. You will need to be able to work over the top of the floor channel to get at the screws that hold the channel to the floor. You cant do that by just prying the lower edge of the interior panel out from the wall.
2. Remove the belly pan? The bottom row of exterior rivets go through the upper skin, then through the belly pan, then into the floor channel. After you have removed the bottom row of exterior rivets, run a putty knife between the belly skin and the body skin to break loose the rivets. You will find some 'hidden' rivets that are under the body skin, that hold the belly skin to the floor channel. drill these out also. I found it easier to remove a couple of vertical rivets on the body so that I could pry the skin out far enough to get at the hidden rivets.
3. Before you try to lift the body, carefully measure the distance between the main ribs, front to back, side to side, and diagonally. Put in 2x4 bracing from side to side and front to back, anchoring the main ribs, and cross brace to prevent racking. These 2x4s will be the lifting points you use to jack up the body.
4. Before you try to lift the body, go completely around the perimeter again, inside and out, with a putty knife to make sure all the rivets are gone.
5. Remove all the screws that hold the floor channel to the floor. use the putty knife to check that the floor channel is completely free from the floor.
6. Now you can start to pry the body up a few inches using a jack, or even just a crowbar and some wood blocks. Be carefull if you use a crowbar because the whole body will start to 'walk around' unless you keep it level.
7. I didn't have any help lifting the body off. I jacked it up high enough to clear the wheelwells, then hitched the frame up and drove it out. This is very scary unless you have the shell well braced and well supported. I left he belly pan attached until I had the frame out from under the body because I didn't want to be working under the frame with the body up on jacks. I think if you had four people, one at each corner, you could lift the body and walk it off.
8. I removed the belly pan after the body was off. There weren't that many rivets in the belly (maybe 50), and I needed the belly off in order to remove the floor. The belly skin was in two long peices, with a lap joint at the centerline. With a little bit of jostling, I pulled the skins out from the rear. I carefully flattened the edges and rolled it up.
I have quite a few pictures. Let me know if this helps you plan what will be your grand adventure.
markdoane is online now   Reply With Quote
