Old 10-02-2003, 03:36 PM   #1
Send a message via Yahoo to dhe9
sheared rivet
i have a rivet that has been sheared off above and to the left of my door on my bambi. it appears that only the head has come off and the rest of the rivet remains in the body of my stream. any suggestions on what to do?
thanks,
david
dhe9 is offline   Reply With Quote
Old 10-02-2003, 03:39 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
First off, welcome to the forum David! You will find a wealth of information here and lots of folks willing to help you out.
It would be helpful in knowing how to respond to your question(s) if you completed the information portion of your profile. What year is your Bambi? Where are you located?
Shari
Old 10-02-2003, 03:43 PM   #3
sheared rivet
thanks for the info and i will update my info.
my airstream is a 19' bambi 2003 and i am going to let the dealer replace the rivet what wanted to know for future reference. not sure if this is a common occurance as i am new to airstreaming. my bambi has about 5k miles on it as i have just completed a 3k trip through the intermountain west.
i am in so cal.
thanks,
david
Old 10-02-2003, 03:49 PM   #4
InsideOut's Avatar
1956 22' Safari
Images: 108
Being that it's "new" I would let the dealer fix it.
We've had several "bucked rivets" replaced around the door of our '64 by an airplane mechanic buddy. He charged us $5 a piece.
If you don't want to have the dealer fix it after the warrenty runs out, I would suggest looking for someone who does airplane repairs in your area.
Shari
Old 10-02-2003, 04:25 PM   #5
Images: 59
sheared rivet
Is the rivet inside or out. Inside should be a simple repair with a pop rivet. Teh outside can be replaced with an 'Olympic' rivet.
Bucked rivets cost 10 cents. But that's just material. Labor is extra.
Old 10-02-2003, 05:16 PM   #6
rivets
mark,
the rivet is outside. does this web site have any info on fixing this? i am going to let the "stealer" repair it as i still have the warranty.
thanks,
david
'03 19' bambi
2011 CTD DIESEL
SEMPER FI
RETIRED USMC
Old 10-02-2003, 05:52 PM   #7
Images: 59
Rivets
Yeah, the stealer should repair ir if it's under warranty. Keep an eye on it, if it pops again it may indicate a lot of stress on that area.
Look under Forums>exterior repair for lots of threads on replacing rivets
Don in Minnetonka, aka markdoane
Old 10-02-2003, 06:13 PM   #8
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Re: rivets
Try clicking on the "search" button and entering "rivet" or "rivet repair" and you will find a wealth of information. Happy hunting!
yukionna is offline   Reply With Quote
Old 10-03-2003, 08:16 AM   #9
Shearing Rivets.
Shearing rivets are related to shock and/or vibration.
If the "running gear" is not properly balanced, shearing of rivets will occur.
Stopping or preventing shearing can easily be done with a proper running gear balance.
Olympic rivet removal and installation PeterH-Airstreamer Ribs, Skins & Rivets 90 11-07-2012 01:34 PM
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 05:51 PM
Ebay rivet shaver TomW Ribs, Skins & Rivets 4 02-26-2004 01:54 PM
Rivet Removal pap Ribs, Skins & Rivets 11 02-06-2004 10:04 PM
