Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 05-01-2007, 12:26 PM   #1
craftsman
craftsman's Avatar
Profile:  2007 25' Classic
Hydes , Maryland
Sharp Sheet Metal Screws!!
The screens on my 25' Classic are screwed to the window frames using 3/4" #8 sheet metal screws with a white painted head. If you leave your windows open at camp grounds, eventually you'll be cleaning the sills of your windows, which you have to do from outside. Well these sheet metal screws are way to long for the job that they do. They stick out a good 1/2" past the frame and will cut your hand if your not really carefull. I went to the big box hardware store and bought the same #8 screws only 1/2" instead then I cut off the points with a pair of snips and ground the points flat using an abrasive wheel on a Dremel tool.. The screws are now only 3/8" long ;big difference. Tighten them down and they only protrude about 1/8" past the frame at the most and the holding power is just as good. Now you can get a cleaning rag in there with out fear of cutting yourself. Don't look for these screws in the hardware section instead you'll find them in the section with down spouts and gutters. Seems like a lot of work but it really isn't. You only need to change out the bottom row and I did the first screw up either side also. I also changed out all the exterior rusting steel screws on the exterior of the trailer with stainless steel.
craftsman is offline   Reply With Quote
Old 05-01-2007, 01:21 PM   #2
TIMEMACHINE
TIMEMACHINE's Avatar
Huntington Beach , California
Great tip Craftsman2.......I have wondered if those screws were only in my AS since none of the screws used are sized properly throught my unit. Either too long or too short or too fat or too thin. And of course, there are the rusty ones. Basically, we have been screwed as far as fasteners go, pun intended.
Airstream needs new engineers to improve screwing procedures.
Time
Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
TIMEMACHINE is offline   Reply With Quote
Old 05-01-2007, 01:48 PM   #3
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
I had that problem on the Excella, so I guess they've been doing that same dumb stunt for years and years. I replace the screws with truss head SS 8/32 machine screws and aluminum rivet nuts made by Gesipa.
http://www.gesipausa.com/olympic.htm
I bought the tool from McMaster-Carr. I use it all the time and have replaced fasteners all over the rig. You can get aluminum or steel inserts in various sizes. It gives a much more professional result. I'll post some pics of the tool and the screen modification.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-01-2007, 01:53 PM   #4
2airishuman
2airishuman's Avatar
Profile:
yea those screws are part of the airstream security system...
when a bad guy tries to enter via an open window...
he gets poked or ruins a fresh manicure!
i've considered using a dremel to cut off the current screws and soften the tips...
every time i clean those channels...
good tip craftsman...
cheers
2air'
Old 05-01-2007, 03:25 PM   #5
Steve & Susan
Steve & Susan's Avatar
Profile:  2005 28' International CCD
Willoughby , Ohio
I like your replacement idea - I have a few nicks from cleaning windows too.
I got a new Dremel tool as a premium for a hotel/travel club I belong to because I travel a lot for my job. Its second use (the first was to sharpen lawnmower blades) will be to smooth the corners of the 'gutters' above each window. I've Walbernized our AS four times already and all four times managed to peel many layers of skin off my fingers as I ran into these babies.
Shame on me for not learning the first time, but I'm SURE there are others of you out there who have done the same.
I'll try the Dremel on the screws as well!
Steve & Susan
2005 28' CCD, 2002 Silverado-C1500, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 05-01-2007, 05:02 PM   #6
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
If you prefer not to cut the screws off. Take a small paint brush and cover the tip of the screw with this stuff. It comes in clear and will cushion the sharp edge.
Clear Plasti Dip Multi-Purpose Rubber Coating, Dipping Can, 14.5 Fluid oz. - PLD-11609-6
$7.99
Description | Warranty
Plasti Dip multi-purpose coatings allow you to rubberize just about anything! Plasti Dip is a flexable synthetic multi-purpose coating that exhibits excellent moisture, acid, alkaline, and abrasion resistance.
  • Flexable - Won't crack, chip, or become brittle
  • Insulates - Electrical shock, vibration, and heat
  • Grip - Provides safe non-slip comfort and control
  • Durable - Resists weather, chemicals, impact, and abrasion
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 05-01-2007, 06:22 PM   #7
Wabbiteer
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
Riv-nuts! Great idea... thanks now I have an excuse to have bought another tool
Powered by Tinnitus
RE & Alt Energy Hope Chest
RE Forums
Old 05-01-2007, 06:42 PM   #8
Excella CM
Excella CM's Avatar
Venice , California
Here are some shots of the Gesipa riv-nut system. They come in various sizes and grip ranges. These are 8/32. One nice thing is that these nuts are serrated, so that they grip wdhen they are set with the tool and wont work loose.
ID:	36623  Click image for larger version
ID:	36625  Click image for larger version
Old 05-01-2007, 07:17 PM   #9
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Actually from a manufacturing standpoint all screws the lenght of the longest necessary for the trailer makes it so the people assembling do not have to worry about which screw for which hole.
Michelle
I'm not afraid I learned to drive in Washington, DC
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar)
http://Michelles-Adventures.US
Old 05-01-2007, 07:19 PM   #10
thecatsandi
Missoula , Montana
Be careful with rivnuts. We use them in airplanes and I hate them. It is very easy to over stress them putting them in and is the nut gets loose the screw is nearly impossible to remove or insert.
Michelle
Sarah
Old 05-01-2007, 07:26 PM   #11
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
How True !!!!!!!
I'm with ya Michelle!!!! Been There....Done That!!! I used Riv-nuts extensively when I built my Lexan hurrican shutter system. They work great until they don't........then they are a royal PIA to remove. If they are loose and spinning, it's really hard to get the drill bit to bite.
Other than that.....they're great!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 05-02-2007, 08:13 AM   #12
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
I also hate rivnuts for the same reasons stated by Lewster and thecatsandi. I.ll put in a nutplate anytime over a rivnut. Once a spinning rivnut is removed the nole is so big nothing can be done with it. We don't use them at all on either of our aircraft.
Old 05-02-2007, 08:23 AM   #13
craftsman
craftsman's Avatar
Hydes , Maryland
Rivnuts definatly have their place but with the screens and frames it's not only the sharpness of a sheet metal screw sticking past the frame it's the length. The idea was to not only eliminate the point but to reduce the length to the shortest possible so that you can actually clean the sills with a minimum of obstruction. My wife has the digital camera in Holland and I'll take some photo's this weekend when she returns.
Old 05-02-2007, 09:45 AM   #14
Wabbiteer
Wabbiteer's Avatar
1972 29' Ambassador
So now I need a MIG welder to tack down the riv-nuts, bonus tool!
Maybe Screendoor insert panel clips into liners and do away with through-bolts into window frame all together... There are myraid flavors of little clips available - one of them surely could be adapted?
Powered by Tinnitus
RE Forums
Sheet Aluminum repair lee_jachter Ribs, Skins & Rivets 8 11-23-2002 09:48 AM
Nasty sharp corner Pahaska 2003 International 0 11-10-2002 05:52 PM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 04:40 AM
Screws... Chuck Ribs, Skins & Rivets 1 10-21-2002 09:22 AM
Clutch head screws Zed2 Windows & Screens 4 08-23-2002 06:16 PM
test
Airstream Forums -
