Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 05-02-2007, 10:53 AM   #15
doorgunner
INSANITY CENTRAL
doorgunner's Avatar
Profile:  1986 32' Excella
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
I'm with the other airplane folks! Down on rivnuts! altho in this application when one starts spinning you can get to the back side and clamp on a pair of vicegrips so you can drill it out. I pull my screens every so often to hose them off do a good cleaning, while they are off I then detail the frame work with no screws to cut me up. As I'm redoing my window treatment I'll be tapping out all the holes that hold the screens in place and replacing with truss head machine screws, and a dab of loctite. Just my input. DG
www.popasmoke.com
Proud Appellation American
doorgunner is offline   Reply With Quote
Old 05-02-2007, 04:46 PM   #16
nickcrowhurst
Profile:
Back in 2003, replacing these ghastly screws with stainless bolts was described here:
http://www.airforums.com/forums/f164...ment-8426.html?
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 05-02-2007, 04:54 PM   #17
nickcrowhurst
Profile:
And, in 2004:
http://www.airforums.com/forums/92706-post5.html
Nick.
Old 05-02-2007, 04:58 PM   #18
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Deja vu-all over again?
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-02-2007, 05:01 PM   #19
craftsman
craftsman's Avatar
Profile:  2007 25' Classic
Hydes , Maryland
Nick, good detective work. I actually thought about nuts, washers and bolts but I thought it may just be to much work if I ever had to remove the screens for cleaning. It' is a good option though.
craftsman is offline   Reply With Quote
Old 05-02-2007, 05:12 PM   #20
nickcrowhurst
Profile:
Yes, unfortunately. The current method of using the sharp screws is certainly the least skilled, quickest, easiest and most horrible way to install the screens.
Nick.
Sheet Aluminum repair lee_jachter Ribs, Skins & Rivets 8 11-23-2002 09:48 AM
Nasty sharp corner Pahaska 2003 International 0 11-10-2002 05:52 PM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 04:40 AM
Screws... Chuck Ribs, Skins & Rivets 1 10-21-2002 09:22 AM
Clutch head screws Zed2 Windows & Screens 4 08-23-2002 06:16 PM
test
