10-13-2016, 07:59 PM
2004 30' Classic
San Antonio
Seams sealant bleeding.
I have a 2004 classic 31 ft. It seems that the sealant is weeping out from the seams. It looks like hair blowing in the wind while riding a motorcycle. Is it epoxy? If so I read that a heat gun will help remove it. Cleaning fluids are not working. If I scrape then I mar the skin. What caused it is a mystery.
10-13-2016, 08:09 PM
2010 27' FB Classic
N/A
Never heard of that happening before on an Airstream product. Sounds like whoever owned it before you used the wrong sealer on that trailer. Can you contact the previous owner?
10-13-2016, 08:46 PM
2004 30' Classic
San Antonio
I am the only owner. Is it epoxy?
10-13-2016, 09:01 PM
2004 30' Classic
San Antonio
Trying to tag a picture. it worked.
10-13-2016, 09:07 PM
2014 25' Flying Cloud
San Luis Obispo
Looks like filiform corrosion to me. Bummer.
2014 Flying Cloud - 25' RB
2016 Tundra
Air# 42643; WBCCI# 3884
10-13-2016, 09:08 PM
Oswego
Yup, filiform.
-Rich-
10-14-2016, 12:12 PM
2004 30' Classic
San Antonio
And that is caused by?
10-14-2016, 01:52 PM
2006 19' Safari
East Greenbush
, New York
Filiform corrosion is the aluminum corroding under the clearcoat. It happens when water gets under the clearcoat, usually near the edge of a panel.
Lots of threads on this. Search for filiform.
Matt
2006 Safari Bambi 19'
2017 Silverado LT Z71 Double Cab 1500
10-14-2016, 02:21 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
Seconded
10-15-2016, 03:41 PM
2004 30' Classic
San Antonio
I have noticed that it is only happening on the side that is not getting sun. My trailer is under a cover and the sun hits it on the side facing the noon sun. In some places the clear coat is coming off like powder. Amazing. Something else for me to do.
10-22-2016, 08:22 PM
Vintage Kin
Fort Worth
Naw, just get some crappy eyeglasses next time. What you can't see won't bother you.
1990 35' Silver Streak
2004 555 Cummins
10-22-2016, 11:19 PM
2007 23' Safari SE
San Diego
... along with a little reading:
Corrosion problems with new Airstreams
10-23-2016, 08:56 PM
2004 30' Classic
San Antonio
Not when it eats into the aluminum. Thanks for the Texas wit. Living in SA I understand Texas humor.
10-23-2016, 10:36 PM
Mantua
, Ohio
It's cosmetic. Looks bad but will not eat out the aluminum.
10-24-2016, 06:34 AM
Lin
, Ne
Lower grade of aluminum that cost less.
10-24-2016, 11:53 AM
Vintage Kin
Fort Worth
Texas humor does have it moments. I recently had a truck with an air ride seat that had no give. A 260-lb friend jumped aboard to test it and declared it was about as effective in its job as throwing a saddle over a cinder block.
If you live in Texas then I have two strong recommendations. One, a full size dehumidifier (80-100 pint); two, a full cover under which to park to keep sun, polluted rain, hail and the rest off. An enclosed structure is really best. Second to a garage is one which keeps afternoon sun off, not just overhead.
Trailers sit a great deal, and the elements really work on them in this state. My Dads changed quite a lot in appearance the 27-years he had it.
Ive read some of the filiform threads and recommend them. As mine has an anodized skin, it's a different set of problems. Add in possible skin replacement and it's worse (easier to get an AS panel redone).
Good luck
2004 555 Cummins
11-07-2016, 07:02 PM
2004 30' Classic
San Antonio
Average humidity in South Texas today is over 70 percent. I run a dehumidifier full time. It has probably saved my bacon on several occasions after having discovered a wet carpet in the bedroom. I think it's money well spent. Right now pulling up the flooring and it's running like gang busters.
