Old 07-29-2013, 10:08 PM   #1
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
Seam sealer or seam tape
When you are replacing a exterior panel and have a lap joint you need this sealer or tape.
Where does one get this ?
David
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 07-30-2013, 12:53 AM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Hi David...I know what you're doing!
When we do our panel work, we use Trempro/Vulkem (available from VTS) in the overlapping panel joints. Not sure if you are using bucked or Olympic rivets (assuming Olympics), but we also dip each one in Trempro before pulling them. It's a messy proposition, but it seals everything up real well.
Good luck - Moby will be as good as new before long ~
Shari
