Old 02-09-2015, 01:04 PM   #1
Portland , Oregon
Sealing new skin Panels
Finally getting around to replacing a bunch of ribs and installing some new exterior panels on my 1952 Clipper. My question is do I need to apply any type of sealant on the overlap between the panels. I have some Tremco 635. Should I apply a thin layer or should I use something else? I am already using this to seal all the interior seams.
Robert
bikeukeguy is offline   Reply With Quote
Old 02-09-2015, 02:18 PM   #2
1958 26' Overlander
Lander , Wyoming
Yes. trempro would be appropriate to seal between panels.
n2batr is offline   Reply With Quote
Reseating and sealing window frame after replacing a skin Aktundra Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 08-29-2014 07:48 AM
Adding panels on top of panels instead of replacing? The-Marco Ribs, Skins & Rivets 18 08-02-2014 04:53 PM
Detecting / Sealing Leaking Rivets Without Removing Inner Skin HolyRoller Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-10-2011 03:33 PM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
