Old 03-14-2011, 08:49 PM   #1
1968 26' Overlander
West Richland , Washington
Seal or Polish first
I've been cleaning off the silicone and hot glue from many seams as well as the windows (thanks to PO). Eventually I'd like to polish up the little lady but I've got lots of repairs yet to go, vents to remove/replace, etc. Question is should I go ahead and polish those areas where I remove the goop or clean up seams before I seal them up. Does the polishing abrade the sealant or mess it up some how??
JIMandPJ is offline   Reply With Quote
Old 03-14-2011, 08:55 PM   #2
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
I hate silicone!!! I would polish any area you plan to seal, basically like cutting in for painting. That way you have the best surface for your sealer with no grime to compromise the bond.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
wally:Restoring Wally Byam's 1955 26' European Caravan Trailer![/COLOR]
goransons is offline   Reply With Quote
Old 03-14-2011, 09:00 PM   #3
x
XXXX , XXXX
Yes it does mess up the sealant and your polish job. Don't ask me how I know. Polish the areas first then seal up.
wasagachris is offline   Reply With Quote
Old 03-14-2011, 10:03 PM   #4
1968 26' Overlander
Thanks guys - polish it is
Old 03-14-2011, 11:58 PM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Thumbs up Sounds like you are on the right track...
We scrape out the old sealer, polish the seams then reseal them. Our reasoning is in post #472 of our "It's a Girl!!!" restoration thread.
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Removing haze after polish ALí UM- MONEY Cleaning, Stripping & Polishing 5 01-31-2011 07:42 PM
Will gasket material seal the rear bumper storage? tvanwave Bumpers & Bumper Storage 0 01-31-2011 04:00 PM
Use what to seal holes/cracks for bugs/mice prevention? BrianD. Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 01-29-2011 07:50 AM
86 SOV Polish Questions - Need Just a LITTLE help! big_john Cleaning, Stripping & Polishing 7 01-14-2011 02:52 PM
Temporary Seal for Vista views AluminumGirl Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 01-08-2011 11:06 AM
