Old 05-19-2015, 08:43 AM   #1
1964 24' Tradewind
Lawrence , Kansas
Screws and Aluminum and Rust
If one is forced to use a screw that will come in contract with the aluminum what is the best metal make up of the screw? Should the screw be coated? Thanks in advance.
ttbikes is offline   Reply With Quote
Old 05-19-2015, 09:13 AM   #2
aquinob's Avatar
Portsmouth , Virginia
Always use stainless, especially if it is exposed to weather.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 05-19-2015, 09:21 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I second that recommendation.
Chris
Old 05-19-2015, 09:21 AM   #4
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Cadmium plated aircraft screws work well, should you choose to go that route.
Old 05-19-2015, 09:26 AM   #5
dznf0g's Avatar
Oswego , Illinois
I replace with stainless on each project and where corrosion becomes an issue.
Depending upon application I sometimes use a nylon washer/insulator and/or corrosion-Ex to retard the galvanic reaction.
-Rich-
Old 05-19-2015, 09:27 AM   #6
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
The 18-8 stainless screw grade should be type 304 or 305 as they have a higher corrosion resistance due to a lower carbon content (.08).
NWRVR is offline   Reply With Quote
Old 05-19-2015, 10:31 AM   #7
davidwrogers's Avatar
Charleston , South Carolina
Galvanic Corrosion
Stainless steel fasteners have been covered and are the best option but one more is Loctite 222 for small fasteners. It prevents galvanic corrosion between the threads of dissimilar metals and prevents them from vibrating loose. Because it is low strength you will be able to back the screws out using a screwdriver. Do not use Loctite 262 unless you never want to remove the screw. 222 is pink in color and 262 is red. Hope you find something that works for you.
davidwrogers is offline   Reply With Quote
Old 05-19-2015, 10:35 AM   #8
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Stainless and here is what you coat the threads with prior to use.
Howard L. is offline   Reply With Quote
Old 05-19-2015, 11:47 AM   #9
1967 26' Overlander
Spartanburg , South Carolina
As an old retired plant engineer, I agree with most of the comments esp using Loctite to prevent galvanic corrosion. There are other products available for that but my experience with Loctite in general is they know their business. They also have a very good customer service department who will talk with you on the phone.
Don't know about the Permatex with aluminum and suggest you read the label and/or go to their web site for more info before using. I would also suggest using aluminum screws where the application will allow the lower tensile strength. That will generally eliminate galvanic corrosion or at least minimize it depending on the alloy.
Jacob D is offline   Reply With Quote
Old 05-19-2015, 11:56 AM   #10
1996 25' Excella
Tillsonburg , Ontario
I noted in a previous thread on this topic that I used SS on the stainless fittings on my sailboat Aluminum mast. Never had a problem. Some one noted that they were an Aerospace engineer and they use SS on airplane aluminum all the time.
JCW
JCWDCW is offline   Reply With Quote
Old 05-19-2015, 12:12 PM   #11
Kevin245's Avatar
Ditto on the stainless steel recommendations. Galvanic corrosion is the big concern joining dissimilar metals. Rust is a by-product of ferrous metal corrosion, but using stainless will ease your concerns over discoloration.
Eleanor Roosevelt
Old 05-19-2015, 01:10 PM   #12
1981 31' Excella II
New Market , Alabama
Aluminum and Stainless steel are pretty good at self insulating each other and should not have a huge problem with galvanic corrosion with each other. A hot dip galvanized washer as an anode is not a bad idea. Thin electroplated washers won't last long because the coating is not thick enough to last long. Belly skins have the most corrosion issues because of road salt and water leaks from above and soaked insulation.
Perry
Old 05-19-2015, 08:52 PM   #13
1964 24' Tradewind
Lawrence , Kansas
Good info. Thanks everyone.
Old 05-20-2015, 09:15 AM   #14
Howard L.'s Avatar
San Antonio , Texas
A follow up on Jacob's note of caution: I've used Permatex for years in the salt water marine environment of stainless screws/bolts and aluminum. You have to try real hard to get much worse than that.
Product Description
Permatex Anti-Seize Lubricant is a highly refined blend of aluminum, copper and graphite lubricants, for use during assembly to prevent galling, corrosion and seizing, and to assure easier disassembly. Featuring salt, corrosion and moisture resistance, this lubricant is ideal for marine use. With a temperature range from -60 degrees Fahrenheit to 1600 degrees Fahrenheit, it will not evaporate or harden in extreme temperatures.
Rust and Frames Por 15 Zero Rust Tony S Repairing/Replacing Floor &/or Frame 10 02-20-2013 03:45 PM
Nails and screws r carl Tires 4 09-11-2010 07:20 PM
Where to put j bolts, screws and adhesive JoePfznik Repairing/Replacing Floor &/or Frame 1 12-17-2009 07:29 AM
Screws and fasteners other than rivets cameront120 Ribs, Skins & Rivets 5 06-28-2007 12:21 PM
Rub Rail and Metal Screws cameront120 Ribs, Skins & Rivets 4 03-29-2006 07:35 PM
