Old 05-20-2015, 01:29 PM   #15
1981 31' Excella II
New Market , Alabama
Anti Seize is never a bad idea with heat and corrosion environments.
Perry
Old 05-21-2015, 09:40 AM   #16
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
If anti-seize is used it should be zinc based anti-seize with no copper content according to the builder of my aluminium jet boat. Loctite product number 39901 is zinc based and will minimize galvanic corrosion.
Also, I would not use zinc plated washers or any zinc plated fasteners because the zinc acts as a sacrificial anode and after a few years the underlying carbon steel will come into contact with the aluminium resulting in corrosion.
NWRVR is offline   Reply With Quote
Old 05-21-2015, 12:08 PM   #17
1981 31' Excella II
The double dip galvanized steel washers are made for corrosive environments and that is why the coating is so thick. Stainless steel is fine as well but it might tend to corrode the aluminum since it is cathodic to aluminum.
Perry
Old 05-23-2015, 07:21 PM   #18
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
All these products minimize galvanic corrosion--that's what we're talking about here. I personally don't buy your jet boat builder's no copper story since original Permatex has been used on aluminum in the saltwater/aluminum boating industry, with no problems, long before Locktite ever produced an anti seize product. That said, if one is afraid of copper, use a copper free product. Heck, use the food safe stuff if you want, just use Stainless and some anti seize--done deal.
Howard
Howard L. is offline   Reply With Quote
Old 05-24-2015, 12:20 AM   #19
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Howard
My North River Commander 21 is nine years old without any signs of corrosion so I'll go with what the builder recommends. In the late 80s I owned a marine repair business and we drilled out many corroded bolts from out drives and out boards. Preventative maintenance has come a long ways since then so I'll go with what the guys recommend that build the high dollar aluminium toys today. All we can do is post recommendations for the original poster and from that, he/she can make a decision or seek more competent advice.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
Old 05-25-2015, 07:38 PM   #20
Howard L.'s Avatar
San Antonio , Texas
Absolutely, to each his own. Just use something
Rust and Frames Por 15 Zero Rust Tony S Repairing/Replacing Floor &/or Frame 10 02-20-2013 03:45 PM
Nails and screws r carl Tires 4 09-11-2010 07:20 PM
Where to put j bolts, screws and adhesive JoePfznik Repairing/Replacing Floor &/or Frame 1 12-17-2009 07:29 AM
Screws and fasteners other than rivets cameront120 Ribs, Skins & Rivets 5 06-28-2007 12:21 PM
Rub Rail and Metal Screws cameront120 Ribs, Skins & Rivets 4 03-29-2006 07:35 PM
