Old 12-05-2010, 09:45 PM   #1
Ketchum , Idaho
Scratches...
Hello. I'm new to the airstream rejuvenating business and have a quick question regarding the exterior skins. How hard are surface scratches to remove by buffing out? One scratch is not too deep, its a phone number that has been lightly keyed into the side (how rude of someone to do!). The other is quite a bit deeper, rough to the touch, about 8 inches long and 4 inches high. It looks like someone was intentionally scratching back and forth with some sort of tool.
Buff out or replace the panels? Thanks for the advice!
Meg
mlynn2003 is offline   Reply With Quote
Old 12-06-2010, 12:33 AM   #2
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Scratches
Meg, Have you already stripped the coating off the panels? You will need to strip that off b4 you try to buff out the scratches. If they are not too deep you may be able to buff them completely out. Then buffing the panels to a nice shine is possible. I would not want to try replacing those panels on a nice vintage trailer. Panels can be very expensive and must be installed and seal well or more issues will follow. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is online now   Reply With Quote
Old 12-06-2010, 06:27 AM   #3
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Are you doing a mirror finish on your trailer? If so, you can buff them out with some time & effort. If not, you can still buff them out, but it will be shiny & not match the rest of your trailer.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 12-08-2010, 02:53 PM   #4
Ketchum , Idaho
Thanks!
Thanks for the suggestions. At this time, we have done nothing to the trailer. Since we are new to this, we wanted to take the winter to build a plan of attack and a budget. We know we have to gut the inside. I think there might be a mold problem. We are not sure if the windows leaked or that panels leaked to cause the mold and warped floor. And figured with the inside taken down, if we would also need to replace the scratched panels. We are not sure what finish to even go with at this point.
Old 12-08-2010, 03:37 PM   #5
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
I have had to use a fine sandpaper to get out scratches,you have to progressively go to finer ,then go to the compound. Dave
easyride is offline   Reply With Quote
Removing rust and scratches 67twinkie Cleaning, Stripping & Polishing 2 11-24-2009 01:08 PM
Repairing Skin Scratches brownseyes Cleaning, Stripping & Polishing 2 11-07-2009 03:30 PM
removing light scratches birwine Cleaning, Stripping & Polishing 3 07-07-2009 10:32 AM
Scratches! ...in clearcoat? iHayley Clearcoat, Exterior Paint & Trim 8 06-27-2008 03:58 PM
Scratches Pharmdawg Ribs, Skins & Rivets 1 08-30-2006 10:25 PM
