09-11-2011, 03:21 PM
1974 23' Safari
1947 25' Spartan
, Manor
Scratch removal:-(
Hi,
so the Safari I purchased has a few scratches in it that I would like to polish out when taking off the clear coat and giving it a mirror shine. The scratches were made by the former owners kid with a small rock or something (bad kid! Don't touch!). They aren't amazingly bad ( i can feel them with my fingernail, but are pretty light) and could be taken out with some very fine grit sandpaper. I may want to do this with some other small blemishes on the skin as well.
My questions revolve around the alclad aluminum and how deep the clad on the outside of the alloy is.
1- Is there a big risk of sanding through the outer clad into the alloy which might then not be able to take the mirror shine?
2- If sanding with fine grit is acceptable then does anyone have a suggestion of the most corse grit to START with (I'd then work my way to the finer paper and then buffing).
Thank you all in advance!
Eric
09-11-2011, 03:23 PM
2014 25' Flying Cloud
Cuddebackville
, New York
I've had several what looked like scratches from tree branches that came right out with Walberize. Rocks sound worse.
09-12-2011, 10:27 AM
1974 23' Safari
1947 25' Spartan
, Manor
Yea, they aren't too bad...
Any thoughts on sanding?
Thanks!
09-12-2011, 11:08 AM
1967 17' Caravel
1968 22' Safari
Sacramento
scatch removal
I would avoid sanding. Sanding will REMOVE material to blend the scratches. I would suggest compounding the area of the scratches with a gray bar applied with edge buff. This will allow you to remove the scratches by smearing the surface of the alum. around to blend out the scratches. As you compound you can actually watch the alum. flow around under the pad as you make passes.
09-12-2011, 11:55 AM
1974 23' Safari
1947 25' Spartan
, Manor
Great! Thanks!
Do you have any possible links to share for those products? I can search them, but personal recommendations would be great.
So sanding is a no-no because of possibility of going through the softer aluminum into the alloy?
09-12-2011, 12:00 PM
1965 22' Safari
Vassar
, Michigan
I use the Nuvite system by PerfectPolish.com and have had great results. It will remove scratches as you compound the alum. (might take several passes with the compounder). There is no short cut to a mirror shine. It takes a compounder (side grinder like Dewalt). Several different grades of polish. A Cyclo random orbital polisher using very soft cotton cloth. Plus a great deal of effort.
Sanding is a No - No because it will add many more scratches to the soft Alum. that you will have to compound out.
Tim
TAC MI 14
Everyday is a Saturday
09-12-2011, 12:06 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
atch removal:-(
Greetings Eric!
Something else to keep in mind is that the scratches may be contained by the Plasticoat. There may be minimal, if any, damage to the aluminum lying below the Plasticoat. I would echo the concerns about sanding as a previous owner of my coach tried this approach and it made for a nightmare when I had my Overlander professionally polished a little less than eight years ago.
Good luck with your project!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
09-12-2011, 12:10 PM
1974 23' Safari
1947 25' Spartan
, Manor
Great! I will avoid the sanding and stick to the compounding when we get to that point.
I hear it takes a lot of work to get that shine! I think that will be a job for our interns; we run things like Mr. Miyagi from The Karate Kid around here...the interns have to master buffing to learn filmmaking LOL!
03-23-2014, 10:41 PM
2019 19' Flying Cloud
Costa Mesa
I don't know if this is the correct place in the forum but could use some help. We have owned our 78 Excella for 25 years, it is polished and beautiful! Unfortunately it was vandalized when stored at my shop. The (creeps) could have just thrashed the inside and taken the TV but they had to put deep scratches into the skin as well! Anyway I'm trying to see if these deep scratches can be removed. This is not clear coat scratches they're into the aluminum with a sharp object .
Thank you for any input.
03-24-2014, 02:46 AM
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru
, New York
Originally Posted by Jim Miller
I don't know if this is the correct place in the forum but could use some help. We have owned our 78 Excella for 25 years, it is polished and beautiful! Unfortunately it was vandalized when stored at my shop. The (creeps) could have just thrashed the inside and taken the TV but they had to put deep scratches into the skin as well! Anyway I'm trying to see if these deep scratches can be removed. This is not clear coat scratches they're into the aluminum with a sharp object Attachment 208165Attachment 208165.
Hi Jim,
Wet sand the scratches with 400, 800 & 1200 paper. This works well despite what the posters above thought. Keep in mind that wet sand paper of these grits are nothing more than compound on paper. Take care when using this approach & polish with F9 every once in a while to assess your rate of success. You probably won't get it all out, but you'll certainly soften the scratches & minimize the damage.
Good luck with it.
Colin
03-24-2014, 09:19 AM
Costa Mesa
Colin,
Thank you for the response! Haven't been on the Forum for a while forgot what a great resource it was. I will give this a try. I was worried about the sanding because everybody talking about going through some cladding.
Thanks again!
03-24-2014, 09:36 AM
1959 28' Ambassador
1949 24' Limited
Peru
, New York
Colin,
Thanks again!
You can certainly go through the cladding, as it is only .003" thick, however we wet sand scratches all the time without issues. Depending on the depth, you may not get it all out, but you'll certainly make them look significantly better.
Colin
03-24-2014, 10:05 AM
Costa Mesa
Thanks again Colin!
Any way to know when to stop, before I go through the cladding?
03-24-2014, 10:16 AM
1959 28' Ambassador
1949 24' Limited
Peru
, New York
Thanks again Colin!
This will probably start to happen nearer to the scratch itself. It'll look kinda like an island that is starting to grow in size. Like I said earlier, polish the area every once in a while to determine how far you really need to go, in order to feel comfortable with the job.
Colin
03-24-2014, 10:42 AM
1973 21' Globetrotter
Houston
In the early 70's, AS started using 6061 T6 as an alternate to the 2024 T3. My '73 is made of 6061 T6. In the late 70's, AS switched to 3004-H18. In either case, a trailer made in the 70's very likely does not have Alclad skin, and there should be not worries about sanding through it.
03-24-2014, 10:50 AM
Costa Mesa
Belegedhl,
Thanks that good to hear. Mine is a 78' Excella.
06-26-2019, 05:32 PM
1958 26' Overlander
1962 19' Globetrotter
los angeles
I am working a 65 Globetrotter. Have wet sanded some of the scratches and seems to look good after the F9. Is the skin on the older trailers same material demo inside to outside so cannot sand through and outer layers?
