Old 03-27-2006, 05:22 PM   #1
cameront120's Avatar
1972 25' Tradewind
Rub Rail and Metal Screws
On the rub rail that covers where the exterior aluminum panels meet the belly pan, someone has replaced missing rivets with sheet metal screws. No doubt, these have created a larger diameter hole than originally needed for the rivets. Can I simply drill the hole out and install a new, larger diameter rivet to correspond with this new diameter hole?
Also, I keep seeing references to #21, # 11 & #30 drill bits. All of the drill bits I see in my local hardware stores are fractional. Does anyone know where I can get these numbered drill bits?
Thanks in advance.
Cheers
North Vancouver, BC
Old 03-27-2006, 05:40 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Thanks in advance.
Cheers
Cameron,
Inland RV had the number drill bits in a set of seven, I think, for about $8 US. However, they only ship orders totaling over $25, so you could order three sets or something else.
Bill
Just my personal opinion
Old 03-27-2006, 05:41 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Cameron,
Number drill bits are in-between the fractional sizes. Look at a local machine shop supplier or go to www.mcmaster.com.
Old 03-29-2006, 05:14 PM   #4
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
I am doing a aft end replacement on a 1997 and the factory has used long screws and rivets. Might use the long screws to draw the moulding into position for the rivets. I am in the take apart stage.
Paul
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old 03-29-2006, 07:35 PM   #5
1972 25' Tradewind
Paul
Did they stagger/alternate the rivets with long screws?
Thanks for the tips on the drill bits lewster and wkerfoot, I found a local machine shop supplier that has them in stock.
North Vancouver, BC
Where are the jack points? barbwire All Argosy Trailers 6 11-11-2002 09:52 AM
seal the bottom edge trim pieces? cindy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 10-23-2002 09:18 AM
