Old 10-03-2015, 07:05 PM   #15
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
So, i dont have a thermostat with settings by degrees, its the old Coleman Mach with a rotary sw to set temp. Is the objective to get the AC to run but not have the compressor kick in? (My AC knowledge is pretty limited)
mayco is online now   Reply With Quote
Old 10-03-2015, 07:27 PM   #16
1979 23' Safari
Wayland , New York
The goal is to get the ac to run once in a while to act as a dehumidifier but not overwhelm the furnace. Compressor will run. You end up cooling and heating thectrailer at the same time. A dehumidifier would be the better option if you have room.
Old 10-03-2015, 07:37 PM   #17
mayco's Avatar
Thanks, that what I was looking for. Thank you for the explanation.
Old 10-03-2015, 08:02 PM   #18
CRH
1995 25' Excella
xxxxx , xxxxxx
I had a hard sided popup. It sweated alot inside during damp, rainy conditions. I often ran a heater and the AC to keep the air dry.
CRH is online now   Reply With Quote
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 12:23 PM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-28-2007 12:03 AM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 06:49 PM
Rivit Master and not even ready to roll! malconium Our Community 4 08-15-2005 10:25 PM
rivit replacement nevisstudio Ribs, Skins & Rivets 2 08-01-2005 05:19 PM
