Old 09-03-2016, 06:44 PM   #1
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Rivets to fasten taillights to skin from inside?
OK, well there might have been an issue with a tree. And I might need to fasten the right taillight housing back onto a new skin patch.
What kind of rivets should I use?
Thsnks!
Old 09-03-2016, 10:07 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If the rivets are inside the light fixture you can use standard pop rivets. Even if the rivets are exposed a little sealant along with pop rivets will do. The rub rail on your coach is attached with pop rivets.
Old 09-04-2016, 11:10 AM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
You Might be able to use pop rivets to attach the light housing to the repair before you rivet the patch on
Old 09-04-2016, 11:17 AM   #4
drboyd's Avatar
1978 25' Tradewind
The rivets that were originally used didn't look like "regular" pop rivets; they hold in a part of the taillight bezel that's roughly an inch thick.
Old 09-04-2016, 11:23 AM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You can get different length pop rivets. You can get Olympic rivets as well. But you will have to shave the Olympic rivet unless it is hidden then you can just clip them off.
Old 09-04-2016, 11:33 AM   #6
Aerowood's Avatar
Arvada , Colorado
When I reinstalled my tail light housings I installed heli-coils and then just bolted them on from the inside is the skin
Best way to fasten 'stuff' to the belly pan ? RFP 2011 - 2015 International 8 04-06-2016 08:42 PM
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 01:53 PM
How to Fasten Underlayment to Subfloor AStreamJake Floor Finishes 4 09-17-2014 06:32 PM
how to fasten tail light assembly '73 Soverign cuyd Lights - Interior & Exterior 3 06-22-2008 02:08 PM
1971 rear taillights inside metal cups mikenlyn Lights - Interior & Exterior 13 07-28-2004 04:47 PM
