Old 01-26-2014, 07:38 PM   #29
1972 21' Globetrotter
Wylie , Texas
Aerowood-
I have confidence in your experience. It seems that universals are a good option based particularly on their availability. So I have two questions:
1) Do you recommend the 2117 alloy exclusively, or do you only use these for structural repairs and the soft for seams?
2) What rivet gun do you recommend. You mentioned mine may be underpowered for ADs. If mine will work for some, but not all I would hope there was another you could recommend that may be more suitable (and preferably versatile). But since the structural areas are the only ones I am solid riveting, my preference if I have to go with one over the other would be one made to handle the 2117s of 1/8 to 5/32 diameter. Unfortunately my budget or space does not allow an unlimited supply of rivet guns.
Hope I am making sense.
rippie is offline   Reply With Quote
Old 01-27-2014, 07:18 AM   #30
Wylie , Texas
To reiterate, I have the rivet gun from VTS. Some doubt was expressed as to whether this will be powerful enough to properly expand the harder alloy rivets. I would be grateful for any recommendations/advice on obtaining a proper rivet gun for this application. (Most likely 1/8 to 5/32 diameter of approx. 3/4" length)
Old 01-27-2014, 07:53 AM   #31
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I only mentioned that your 3X rivet gun may not have the power to shoot an AD rivet that is a -12 in length. This would require that the total materiel stackup for the -12 length would be in the neighborhood of 9/16ths thick. I did not inquire as to where on your trailer, are you going to have that materiel thickness to shoot together. That's a pretty good buildup. The 3x gun you purchased has more then enough power to shoot 99.9% of the rivets on your trailer, in AD's. For the bulk of your shooting you will be using -4's and -5's.
Old 01-27-2014, 08:26 AM   #32
Aerowood's Avatar
Arvada , Colorado
Originally Posted by goshawks00 View Post
and the 20............?
I talked to our Aircraft Structural Engineer here at work as to what the 20 stood for and and he didn't know either. We thought it might mean rivet but there are other p/n like clevis pins that start with MS20 also, so that theory went out the door to. So then we looked at the now obsolete AN numbers and if you convert the AN number to MS without adding the 20 you get a part number that is not a rivet, as that number was already used in the MS system. So the only guess we could come up with is that when converting from AN to MS they had to add the 20 because the original AN rivet p/n or a portion of it was already in use by the MS spec.
One other thing that is changing is the DOD is discontinuing support for some the MS system specs. and a lot (about 500 right know) of former MS numbers are being supported by the AIA (Aerospace Industries Association) and will be NASM numbers.
Old 01-27-2014, 11:58 AM   #33
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Thanks you for searching it out!!
goshawks00 is offline   Reply With Quote
Old 01-27-2014, 02:53 PM   #34
Wylie , Texas
The area that I am trying to secure with rivets in the most acceptable way that my means and skills will allow is the rear belt line. I am good in rivet supply for all except the hold down plate area. I am using a jack to squeeze the c-channel to the hold down to the skin. I placed a 1/2" rivet and was able to see only the tail barely on the inside. I did not put a caliper on it, but there was not doubt I did not have enough to buck properly. I decided to search for 1" rivets because I thought I could always cut shorter. I figured on some definite trial and error to determine the actual proper length. I logically assumed that 3/4" length would probably be sufficient, just did not want to risk any more downtime (of which I am enjoying today).
Doing the math: I did add a sheet of Alum that is roughly equivalent to skin material thickness in my attempt to rectify the problem of water seepage under the ply from bumper construction. Even with this, I feel that there should still be more bite from a 1/2", but not from what I could see. It's like the math is not adding up(sum being greater than parts). It made me wonder if the hold down angle may be slightly thicker than original. Any way, still looking at longer than 1/2" based on my observations. So I guess I'll just try the rivet gun I have unless someone can make another recommendation to save me before I make a mistake here.
Game plan: Drive 3/4" length AD(hard alloy) rivet in 1/8" or 5/32" diameter to rear hold down plate area with rivet gun from VTS (?not sure what 3x means?). Any suggested improvements, feedback, or thoughts? Silence will be assumed to indicate consent.
I really do not mean to dwell on this but I would like to proceed with confidence.
Old 01-27-2014, 03:14 PM   #35
Aerowood's Avatar
Arvada , Colorado
Why are you having to use a jack to hold things tight? Is your new hold down plate a 90 degree angle? How thick is your hold down plate? Could you post a picture?
Old 01-27-2014, 03:48 PM   #36
Wylie , Texas
You may remember replying to my post about my concern about space between my hold down and c-channel. You recommended bridging the gap without shimming (with Alum strip from Home Depot). So I set up a jack to pull them flush.
I don't know if it is an iPhone thing, but every time I upload the picture it shows up in the "attachment" screen as uploaded. When I close that window to return to my message window, the message is erased and no picture. I'll try one more time. No joy. Maybe I'll try later. It's worked before, but not always.
Old 01-27-2014, 04:40 PM   #37
Aerowood's Avatar
Arvada , Colorado
Are these fasteners going to be covered up by the exterior lower molding, because if they are why don't you just install some #8 stainless steel machine screws.
Old 01-27-2014, 09:15 PM   #38
Wylie , Texas
OK Aerowood-
I have now spun full circle on the airstream wheel. I first was going to do anything I could to avoid buck riveting and the related expenses, opting instead for olympics. I posted a thread "screws vs rivets" where I posed the question of using screws with locknuts. I have since found that while the steel may be strong, it is also more brittle. So where you would use rivets there is more desire for its bending without breaking (tensile?) properties. Most of the literature claims that a rivet is stronger than a bolt. And I was told that Olympics were not structural. So I finally gave in to my personal stubbornness and got the solid riveting kit.
With that being said, maybe the particular area (hold down) in my situation with (questionable thickness for a strong rivet setting) changes the recommendations and considerations. So my head is swimming from all the information I have been trying to process on this. And, yes, it will be covered up by the rub rail. Thanks for hanging with me on this.
DIY tool for cold rivets? pityocamptes General Repair Forum 3 01-25-2012 05:15 PM
Ugly Rivets! Roadrunner Ribs, Skins & Rivets 2 12-04-2011 11:24 AM
Greasy rivets! tphan Ribs, Skins & Rivets 9 09-04-2011 09:41 AM
Larger Interior Rivets? MDSilverado Ribs, Skins & Rivets 3 01-10-2011 06:54 AM
