Old 09-13-2004, 11:09 AM   #1
Over59's Avatar
Putnam , Connecticut
Images: 37
RIVETS, Rivets, and rivets
OK... Someone please explain rivets for those of us who don't get it. I take it a butt rivet is like a hammered rivet working from both side. But are all hand rivets pop rivets. I have some that have three legs the spread out and others that a little ball is pulled through a tube against the sheet metal. I have found aluminum, shiney aluminum and stainless. Some seem thin and others have thicker metal. So... whats the story. I thinks I get the drill hole size thing but the rivets come in a wide range of lengths.
Over59 is offline   Reply With Quote
Old 09-13-2004, 11:48 AM   #2
Wardinbb's Avatar
1964 24' Tradewind
Big Bear Lake , California
I'll step up
The 'bucked' rivets are factory installed. The Olympic shaving head leg style pop rivet is used to replace the bucked. The ball or bulb style aluminum or steel rivets are also pop rivets. Their length is their grip range.
The Olympic's come in one length for the 5/32" diameter. The standard (non-shavable head) come in various lengths and diameters. Which length to use is dependant on how much material your going to sandwich together. What diameter to use is how much strength is required to hold the thing your working on securely in place.
As a side note, I made a serious error in judgement when I replaced the frig vent cover. The new covers (from Inland RV) come 28" in length to replace a 24" original. I simply cut the vent and slid the halfs 4" together and riveted them together. For some unknown reason I used a 3/16" diameter pop rivet. The end result is it looks terrible as the rivets I used were way overkill. The pop rivet heads are larger than the Olympic's as seen on the rest of the coach and now I've got a small Sherman Tank frig vent!
Hope this helps.
Ed
Wardinbb is offline   Reply With Quote
Old 09-13-2004, 05:20 PM   #3
Over59's Avatar
Images: 37
So do the three leg rivets come in difference hardnesses. The ones I have sure seem soft.
Old 09-13-2004, 06:23 PM   #4
Images: 59
Has anyone used Cherrymax blind rivets? They would seem to be a good alternative to Olympic rivets where higher strength is required.
http://www.textronfasteningsystems.c...uct/rivets.htm
Old 09-13-2004, 06:32 PM   #5
Over59's Avatar
Images: 37
Now those are some fancy rivets. Real cool animation to.
Old 09-13-2004, 06:42 PM   #6
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Lightbulb Not sure, but...
After looking at the catalog briefly, I believe the rivet head comes in aluminum, but the shank does not. It's either Alloy Steel or Iconel 600. I also think they are more expensive than Olympic rivets.
Could be a couple of reasons they aren't used on Airstreams...
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 09-13-2004, 07:06 PM   #7
I think a rivet that has a steel shank and aluminum head would be real useful for the belly pan!
Rick
p.s. Shari, you impress me with your use of technical jargon.
Rick Alston is offline   Reply With Quote
Old 09-13-2004, 09:22 PM   #8
greg176's Avatar
Gabriola Island , British Columbia
Cherrymax rivets are the blind rivet used in aviation.They are quite expensive and have a steel shank.They are difficult to drill out.I'm sticking with aluminum pop rivets for the belly pan.
greg176 is offline   Reply With Quote
Old 09-13-2004, 09:53 PM   #9
Wardinbb's Avatar
1964 24' Tradewind
I don't believe so. One hardness fits all. Its like your 400 ft-lb. model. I think what it comes down to is that the Olympic Bulb Tite is the closest match for OEM. The OEM equal is a bucked rivet. Your choice.
Ed
Old 09-13-2004, 10:13 PM   #10
InsideOut's Avatar
1956 22' Safari
Images: 108
Thanks, but...
Don't be impressed...just repeating what I read ~ I look at this kinda technical spec stuff all the time in my business
Shari
Old 09-13-2004, 10:40 PM   #11
JohnG's Avatar
Ed
Ed,
Olympic = OEM >> Not So.
AS uses Soft Rivets. Soft rivets have a tensile strength of 16,000 PSI.
Hard rivets have a tensile strength of 38,000 PSI.
Olympic Rivets have a tensile strength of 245 PSI. This according to their website. http://www.boltproducts.com/marson/...-bulb-tite.html This makes sense because if they had the same high tensile strength as bucked rivets then you wouldn't be able to put them in with a pop rivet gun. They would just be too strong to be workable.
The soft rivet would be the choice to replace with if it weren't for the fact that you have to remove so much inner panel to be able to buck them.This is why Olympic Rivets are suggested for replacement.
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 09-14-2004, 03:27 AM   #12
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
You can Shave the heads too...
which gives the appearance of a bucked rivet. This is another advantage of the Olympic rivets. I don't think this would be feasible with a steel center pin. Also FWIW not sure if it was factory, though I suspect it was, they used steel rivets to install the banana wraps on my unit, and left the center pins hanging out, which made it a major pain to remove them.
Aaron
WBCCI #XXXX AIR #2495
Old 09-14-2004, 04:48 AM   #13
Images: 59
Originally Posted by JohnG
Ed,
John,
Do you know when AS switched to soft rivets? Mine ('59) are all hardened, with the dimple.
Old 09-14-2004, 08:41 AM   #14
Over59's Avatar
Images: 37
What about inside for the interior panels. Olympic or bulb or something else?
Tiny Rivets Chuck Ribs, Skins & Rivets 6 11-28-2015 10:39 AM
Broken rivets in front rluhr Ribs, Skins & Rivets 43 01-10-2005 09:18 AM
Missing Exterior Rivets carls017 Ribs, Skins & Rivets 5 10-13-2003 08:55 AM
Rivets Again davespann Ribs, Skins & Rivets 3 08-03-2003 05:07 PM
Rivets skip Ribs, Skins & Rivets 25 08-03-2003 10:46 AM
