Old 05-01-2012, 12:45 PM   #1
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Rivets popping off
The olympic rivets on my Airstream were missing when I bought it. I had new ones put in and after miles and miles of towing, they all popped off again. Could it be the hitch set up? I use the Equal-i-zer WD hitch. Or something else?
adwriter73 is offline   Reply With Quote
Old 05-01-2012, 01:46 PM   #2
dznf0g's Avatar
Oswego , Illinois
Could very well be. I believe this is one of the areas specifically spelled out by Inland Andy as a stress area for a too stiffly hitched AS.
What are the rating of your Eq bars?
-Rich-
Old 05-01-2012, 01:58 PM   #3
That front hold down plate is getting beaten to death.
What exact tow vehicle do you have?
What exact torsion bar rating and brand is the hitch?
Is the running gear properly balanced?
There is more to it than just replacing the rivets.
After the above questions are answered, I will share with you the easy fixes.
Old 05-01-2012, 02:05 PM   #4
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I blew up the photo and it appears there were more than 20 rivets in that small area behind the propane tanks. Was something attached there at some point? The rivets may have fallen out because they were installed incorrectly or had nothing to grasp.
If those are holes, a sheet of aluminum covering them and sealed well at the edges would solve the problem. It should extend from one storage door to the other.
Gene
Old 05-01-2012, 02:25 PM   #5
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
CrawfordGene, I wondered if they were simply not re-riveted properly. But the head of all of them were sheared off.
I was pulling with a VW Touareg V8, but like I said, they had popped off before I was towing. Was like this when I purchased it, then I replaced them and the same thing happened.
I have the E2 Equalizer WD hitch with the 10K lb bars
Not sure. I did have all new tires put on before this happened.
Old 05-01-2012, 02:25 PM   #6
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Old 05-01-2012, 02:39 PM   #7
dznf0g's Avatar
Oswego , Illinois
My opinion is here re. the hitch:
http://www.airforums.com/forums/f464...est-76068.html
I am a big fan of Centramatic wheel balancers. Use the search function (google) and search on the name.
Toureg has a soft enough suspension. I don't think TV is a factor here.
-Rich-
Old 05-01-2012, 03:05 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I think your WD bars are way to heavy.
Old 05-01-2012, 03:12 PM   #9
Master of Universe
Gene's Avatar
What kind of hitch did the previous owner have? Was it the same one, or another? If another, it is likely not the Equalizer that is the problem.
There have been many threads on hitches and they feature much disagreement. The conclusion I reached is that Equalizer works fine and that even though the dealer put on heavier bars than necessary, it makes no difference. I don't have rivets popping in the front of the trailer, inside or out. Make sure the hitch is adjusted correctly. Consider Centramatics to keep the wheels balanced and provide a smoother ride.
Gene
Old 05-01-2012, 03:14 PM   #10
dznf0g's Avatar
Oswego , Illinois
Gene, don't you have a much larger frame than OP? Look at his pic...it's 4" at the largest...maybe smaller.
-Rich-
Old 05-01-2012, 03:48 PM   #11
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
I will check this wheel balancing thing out. I have had trouble with the larger cabinets staying fastened to the walls, but assumed I just did not secure them properly. The local Airstream shop said that it's possible the frame has come loose from the shell in this area, causing it to flex. If this is the case, what type of reinforcement could I do?
Old 05-01-2012, 03:56 PM   #12
Master of Universe
Gene's Avatar
dzn',
I can't tell if ad's frame is 4" or 5" though if I had to guess, I'd say 4". Mine is 5". His trailer weight dry is between 4,780 and 4,850 and tongue wt. between 545 and 580 depending on the model. Mine is a lot more.
But, if the size of the bars doesn't make a difference, it doesn't make a difference regardless of trailer weight or frame size.
ad', the thread dzn' quoted from has much information, speculation, thoughts and more:
http://www.airforums.com/forums/f464...ort-86138.html
All those holes—maybe a bike rack was mounted there and bolted on. I am guessing you can get behind the panel to put bolts on. If so, use stainless steel nuts and bolts with rubber washers to close them up. Cheaper than a partial panel (my 1st suggestion) and a lot quicker.
Gene
Old 05-01-2012, 03:57 PM   #13
Master of Universe
Gene's Avatar
Have they looked at it? Do you see any separation inside or out? Start searching "front end separation".
Gene
Old 05-01-2012, 04:05 PM   #14
dznf0g's Avatar
Oswego , Illinois
Gene, I think those holes are for the hold down plate that AS added to earlier models to prevent the flexing and separation due to some of the "theories" we all banter about, like spring bar stiffness, TV suspension....etc.
I do think that for a 1000EQ bar there is a huge difference between flex of an A frame between a 4" and 5" frame. I actually think, from the pic that OP has a 3" frame. I do believe he is way "over-hitched".
-Rich-
