Old 03-28-2010, 09:45 AM   #1
1961 24' Tradewind
Oregon City , Oregon
Rivets on 61 Tradewind
Any suggestions for replacing rivets on a 61 tradewind... what to buy etc.?
bgreeley is offline   Reply With Quote
Old 03-28-2010, 09:51 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
This depends on what rivets you are taking about. Are they inside or outside rivets?
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-28-2010, 09:56 AM   #3
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Lee is correct. On the inside - regular ol' pop rivets: typically 1/8" in diameter. Some of the interior rivets were bucked rivets (domed head, no hole) and would be replaced with Olympic rivets. The exterior was mostly bucked rivets as well and since you can't usually get to the backside of the rivet, you'll need Olympics to replace them.
Hope this answers your questions.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
« Painting trim | Top | 33 »
1973 Airstream Tradewind Land Yacht 25' - Window Rivets sysgenss General Repair Forum 1 12-11-2009 07:57 AM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 08:33 AM
Lousy Rivets!/Weak rivets sunk the Titantic? 1956Safari Off Topic Forum 14 04-18-2008 01:35 PM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
