Old 05-16-2016, 08:46 PM   #1
2013 27' FB International
Mandeville , Louisiana
Rivets missing
I have 3 rivets missing just in front of the front sky light in my 27fb sterling. All three in a row. It seems weird, but I guess I can just replace them, correct?
Tcitruck is offline   Reply With Quote
Old 05-16-2016, 09:08 PM   #2
Southwestern , Ohio
Welcome to the forums!
Inside our outside?!
If inside, yes you can replace them with standard pop rivets.
Nuvite-F is offline   Reply With Quote
Old 05-16-2016, 09:10 PM   #3
Yes, inside. Thanks for the quick reply.
Old 05-16-2016, 10:50 PM   #4
israndy's Avatar
2005 39' Skydeck
Alameda , California
Are inside pop rivets different than outside? I know you need to seal the outside ones, but otherwise the same?
My biggest confusion with replacing rivets, after figuring out what tool to use, is just how do I figure out what size rivets to use...?
-Randy
2007 LTV Serenity beater 2005 Airstream SkyDeck
Also a 1999 Jeep Grand Cherokee, 2000 Honda Hybrid Insight, new 2013 Volvo C70 hardtop convertible
And all electric: a 2012 Mitsubishi i-Miev and two 2007 Vectrix VX1 motorcycles, waiting in line for the Model ☰
israndy is offline   Reply With Quote
Old 05-16-2016, 11:35 PM   #5
Southwestern , Ohio
You bet they are!
Two introductory statements:
I see that you have a Skydeck motor home (!) and I don't know how they are constructed. My comments apply to Airstream aluminum trailers.
The outer skin is structural and so far as I know Airstream doesn't use any pop rivets on the outside of the trailer.
With those qualifications,
Inside pop rivets are just ordinary hardware store aluminum pop rivets. When you install them with the pop rivet tool the shank pulls out, leaving a visible hole in the head of the rivet. The interior skin is held together with pop rivets.
If you need to use pop rivets for a repair in the outer skin, you need to use Olympic rivets.
http://www.vintagetrailersupply.com/...-p/vts-179.htm
Olympic rivets are not as strong as the original solid rivets, but are generally considered acceptable for exterior repairs.
Unlike ordinary pop rivets, when you pop an Olympic rivet, a short length of the rivet shank is left sticking out. This is then cut off and shaved flush with the surface of the rivet head using a special shaving tool (or a file).
Olympic rivets can be made waterproof either by a built in rubber seal or by dunking in caulking compound before installing.
The interior rivets that I have replaced have all been 1/8" size. If the hole is not enlarged the rivet can be replaced with another 1/8" rivet. If the hole has stretched or worn oversize then it has to be drilled out for the next larger size rivet (5/32")
Old 05-17-2016, 05:13 AM   #6
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
My first visit on the roof I discovered a missing rivet on the left linear row of rivets. I figured that they missed one! Since then I had one come off in the front area. I replaced them with the pop rivets supplied from Vintage Trailer along with the shaver, etc that I bought. They look original.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Missing title, missing VIN in Texas. kristinatx Title, VIN & Registration 33 02-22-2016 08:54 AM
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
Missing Rivets FreshAir Forum Admin, News and Member Account Info 6 11-17-2006 04:50 AM
Rivets Missing BIGED52 Forum Admin, News and Member Account Info 2 08-19-2006 09:01 PM
Missing Exterior Rivets carls017 Ribs, Skins & Rivets 5 10-13-2003 08:55 AM
