Old 09-21-2015, 03:51 PM   #1
1964 17' Bambi II
Pasadena , California
Rivets Around Door
Does anyone know what rivets I need to use around the door of my 1964 Bambi?
I have to replace about 10 of them and see that the existing ones are smooth on both sides. The rivets I have been using are not smooth on the back. I know the door seal covers them but the length of the rivet will make the door difficult to close and may also damage the seal.
Thank you for any advice.
Steve
UKSteve is offline   Reply With Quote
Old 09-21-2015, 03:55 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Steve I replaced several around the door of my Bambi II with standard all aluminum rivets. Filed the heads down a bit to flatten them out.
MICHAEL
Old 09-23-2015, 12:12 PM   #3
1964 17' Bambi II
Thank You Michael - I will do that and hopefully they will hold and anyway they be hidden by the door seal.
Steve
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
2013 Airstream, rust around rivets HeadWest Doors & Locks 3 07-02-2013 05:44 AM
Humidity around a couple of interior rivets this morning. mikeandnora Ribs, Skins & Rivets 4 05-13-2012 04:54 PM
Corrosion around hinges and rivets ilittle Ribs, Skins & Rivets 3 10-14-2009 06:46 PM
Rivets around windows Minno Windows & Screens 4 08-09-2009 01:32 PM
