Old 01-16-2008, 05:31 PM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
Rivets
Bought some rivets from Aircraft Tool Supply Online Shopping
the part numbers are MS20470-5-4 with "4" character stamp on the top, on the MS20470-5-5 the character "R" stamp on top, this can't be right. Can universal rivets be bought without the character stamp on the top..............thanks
toastie is offline   Reply With Quote
Old 01-16-2008, 05:37 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
you left out the alloy code on the part number. It should be MS20470AD5-4 or -5. Its anybodys guess what type of materail the rivets are made of.
Kip
Old 01-16-2008, 06:01 PM   #3
toastie's Avatar
1955 22' Safari
Kip
This is there description
P/N MS20470-5-4
Rivets, Solid Alum., 1/4 lb., 5/32" Univ., 1/4" Long. Universal head aluminum rivet (AD). diameter: 5/32". length: 1/4". approx. 890 per pound.
Old 01-16-2008, 06:05 PM   #4
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Yes depends on the alloy. Most aircraft rivets have some sort of mark on them so they can be identified.
Michelle TAC MT-0
Sarah, Snowball
Old 01-16-2008, 07:03 PM   #5
Aerowood's Avatar
Arvada , Colorado
I have no idea as to where they get their rivets from. I have seen rivets with a manufactures mark on them and that is most likely what you are seeing. The only thing that is required on an AD (2117-T3 aluminum) is a dimple in the center. If the letter is a issue you might try using a different supplier. A good supplier should be able to tell you with a simple spot check. I use this supplier Genuine Aircraft Hardware Co. and have seen nothing other then the dimple on my rivets, but you never know which supplier they will use next.
Old 01-16-2008, 07:14 PM   #6
toastie's Avatar
1955 22' Safari
Will order some tomorrow..............thanks
Old 04-09-2008, 08:05 AM   #7
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I'm looking at my many rivets from Aircraft Spruce and find all kinds of markings, including the center dimple on the AD (hard) type. One has almost 30% of the circumference filled with lettering. Time to change supplier!
Not that any of this can be seen from 3 feet away, mind you.
Zep
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 08:33 AM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
rivets Bradjun1 Forum Admin, News and Member Account Info 2 10-05-2005 01:14 PM
Rivets!!!!! srgntpepper Ribs, Skins & Rivets 10 08-20-2003 09:46 PM
Rivets Again davespann Ribs, Skins & Rivets 3 08-03-2003 05:07 PM
