Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 05-22-2007, 09:18 PM   #15
48_liner
48_liner's Avatar
Profile:  1948 22' Liner
Squaw Valley , California
The part number on one of the sizes was MS20470-5-5. They have "01DC" cast into the head. I probably purchased some exotic, experimental aircraft rivets instead of the plain jane ones.
I did get my bead roller from Eastwood today so I can start putting the bead edge on the end cap panels.
48_liner is offline   Reply With Quote
Old 05-22-2007, 09:35 PM   #16
markdoane
Profile:  , Minnesota
Images: 59
I found one other instance where a builder from Vans Airforce ran into the same markings from Aircraft Spruce. Back in Dec '05. Don't think he got a clear answer either.
I think it might be some left-overs from some special mfg lot that Aircraft Spruce is trying to get rid of. Don't know why you got the same thing from Aircraft Tools. There must be some backroom connection.
Non-contributing deadbeat.
Old 05-23-2007, 08:20 PM   #17
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
I think you left out the alloy number on the part number, it should be MS20470AD5-5. The AD is the alloy number, in this case 2117 Aluminum.
Old 05-24-2007, 08:02 AM   #18
48_liner
48_liner's Avatar
I called Aircraft Parts yesterday and was told that all their rivets have the cast in numbers. They gave me the number for Guardian Rivet and Fastner in New York. The gentleman there said all their's had the same casting. He was going to check in the back and see if they had an old lot somewhere then give me a call back.
This can't be so difficult. If the part number needs the "AD", am I ordering the wrong ones?
Old 05-25-2007, 07:17 AM   #19
Aerowood
Aerowood's Avatar
Arvada , Colorado
Yes this could be causing the problem. I didn't think that you could even order an aircraft rivet without an alloy number. The part number MS20470AD5-5 breaks down as follows: MS=military standard, 20470=head style, AD=alloy, 5=dia. in 32's, -5=lenght in 16th's. The alloy number breaks down as follows from softest to hardest in aluminum alloy numbers, A=1100- plain head, B=5052-plus on head, AD=2117-dimple on head, D=2017-raised dimple on head. DD=2024-dash dash on head, E=7075-circle on head. The early Airstreams Used AD's. My 1971 uses A's but as I am changing alot of skin and I am replacing them with AD's. I don't know what year Airstream switched over to the softer rivets.
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
Olympic rivets JPAIRSTREAM Ribs, Skins & Rivets 2 09-30-2002 07:21 PM
Rivets and Karma Joan D'Andrea Our Community 4 09-19-2002 07:43 PM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 06:07 PM
Drilling out rivets... Andy R Ribs, Skins & Rivets 2 04-13-2002 03:02 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
