Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 08-16-2004, 09:21 AM
markdoane
Profile:  , Minnesota
Rivet Tools
I'm sure someone has done a shell-off restoration, bought all the riveting tools, and now they're collecting dust.
I'm looking for a rivet gun (2X? 3X?), bucking bars, clecos and stuff like that that someone wants sell.
Otherwise, I plan to buy a set, and then make it available (for sale) to the next person who needs it.
I don't see this as a tool crib/loaner program, that would be too confusing. I think just outright purchase, then sell it off to the next victim for some percentage of the original cost.
I've checked eBay. Lot's of 'well used' stuff. Nothing I would have.
Also, for those who are familiar with the world of rivets, rivet gun size and brand name recommendations are welcome.
There's a fine line between a hobby and a mental illness.
Get rid of these ads... register today, it's FREE
Old 08-16-2004, 11:05 AM
Inland RV Center, In
Commercial Vendor
Profile:  Corona, California
Don.
Harbor Freight is a good place to buy new tools, cheap.
Almost to the degree of using them, throwing them away, and still be bucks ahead.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 08-16-2004, 11:26 AM
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills, California
Don,
I have owned and used a Craftsman Pneumatic rivet gun for a few years now.
It sets Olympics and blind rivets. It was less than $ 100.00
Harbor Freight has a pneumatic hammer that is reasonable, and accepts the buck rivet "chisel".
Uwe
Old 08-16-2004, 11:37 AM
markdoane
Don.
Andy,
Thanks. I just discovered there is a Harbor Freight in Minneapolis. I bought a pneu/hydraulic blind riveter there on Saturday. $33.00. Works like a champ!
I saw the same thing on eBay for $47.
What I'm looking for to do the next step is a regular rivet gun, for solid rivets, with good throttle control. I have an impact hammer, but I think it would get away from me and hammer through the skins before I got the first rivet in place.
Old 08-16-2004, 02:13 PM
malconium
Profile:  1973 31' Sovereign
Portland, Oregon
Hand blind rivit tool works OK...
This weekend I re-installed a panel that I had taken off. It is one of the curved panels that can not be replaced with flat stock. Since I am planning eventually to paint my unit what I did was to remove the panel and pound out the dented and torn area enough that I can use a relatively small amount of bondo to fill the area prior to painting. At any rate I was able to re-install the panel just fine with a hand operated pop-rivit tool. Actually I found it useful to be able to partially set some of the rivits while I fine tuned the position of the panel. I also used a few pan head screws like Andy suggested to help align the panel. In this case I did not have to drill all new holes since the panel already had holes in the correct locations. I think I must have installed around 100 rivits alltogether. Probably the most anoying aspect of the install was that some of the olympic rivits popped their shafts off down inside of the rivit body rather than with the shaft sticking out some. I just drilled them out and reset them with a new rivit.
I nipped off most of the rivit shafts with a bolt cutter and now just have to shave them down flush. Does anyone have any suggestions as to how to do that cleanly enough without hving to buy an expensive rivit shaver just for this job? Or does anyone know of a source of a relatively cheap rivit shaver? I tried grinding a couple down with my Dremel tool which worked but the results are not quite as even as I would like.
By the way since I have the inner skins off I patched the back side of the tear in the panel with Elasto Seal and seam tape. I could have done it while the panel was off too of course but it was easier to hold on to once it was back in place. The tear was basically closed up once I had pounded the panel back into reasonable shape. I just wanted to have a water proof seal until I am ready to bondo the area from the outside. It seems to have worked. If there had been a larger gap left I probably would have used a fiberglass patch kit instead.
Malcolm
Old 08-16-2004, 02:21 PM
malconium
Portland, Oregon
Air chisel vs. rivit gun?
Don,
I have wondered about using an air chisel as a rivit gun.
Does anyone know if an air chisel can be used as a rivit gun as long as the tip is right? I have one that came with an assortment of air tools that I bought for less than $100 that I have not even used yet. I did notice that it has several different types of interchangeable tips. What type of tip does a solid rivit gun have anyway? Would the level of control be different for a rivit gun than for an air chisel?
Malcolm
Old 08-16-2004, 02:26 PM
Commercial Vendor
Malcomb.
The olympic rivet when pulled, will split into thirds.
When one on those "thirds" hits a stiffner, a main bow or a horizontal stringer, the pin will break below the rivet head, since that obstruction will not allow the rivet to properly compress.
The fix?
Drill out the bad rivet. Cut one third of the rivet shank away. Place that side of the rivet next to the hidden obstruction, and set it.
You will now have a rivet that was set correctly.
The cause?
Sometimes the rivet holes are very close to a main bow, etc. Not a problem if you buck rivet. But when you use the olympic rivets, then that's another story, some times.
Caution. Do not keep the rivet that had it's pin break off short, as it has not properly compressed to hold the metal together.
Using an "air chisel is Ok, provided that you cut the air pressure "down." If you don't the air chisel will beat the metal to death.
Inlandrv.com
Old 08-16-2004, 02:29 PM
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston, Texas
Got this riveter off of eBay a couple of weeks ago. Works well and had English instructions on how to maintain it.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=4314460261
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
Old 08-16-2004, 02:45 PM
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay, Florida
Malcolm, Andy hit the rivet on the head.
I have also had luck with paying attention to the position of the rivet as it pertains to the others in the row and guessing where the obstruction is. I make sure that I have a slot between the legs pointed in the direction I think the obstruction may be. This works for me 90% of the time. The other 10% I have to cut a leg.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 08-16-2004, 03:03 PM
Sav'h Steve
Profile:
Smile
Originally Posted by markdoane
Andy,
Don,
I looked on Harbor Freight website and didn't find it. Can you give a description or number?
Steve
Old 08-16-2004, 03:25 PM
malconium
Portland, Oregon
Harbor freight...
Steve,
I think this is what Don found at Harbor Frieght. There appears to be a sale for even less than he paid at the moment ($24.99).
http://www.harborfreight.com/cpi/cta...itemnumber=167
Malcolm
Old 08-16-2004, 03:29 PM
malconium
Portland, Oregon
What does the tip look like?
Andy,
What does the tip look like for solid rivits? Am I picturing a dimple that matches the rounded head of the rivits? Do you sell the appropriate solid rivits?
Malcolm
Old 08-16-2004, 03:50 PM
greg176
greg176's Avatar
Profile:  1961 26' Overlander
Gabriola Island, British Columbia
Here is a photo of the rivet gun and bucking bar I am using.It is a 4x (a 3x would do) from aircraft tool supply.
http://www.aircraft-tool.com/shop/de... asp?PageNo=2
It has a very nice trigger which gives a lot of control.I would not use an air hammer to buck rivets.I looked at my two air hammers and their triggers are more or less on/off no control.I installed a valve on air inlet to throttle down pressure a little.You will also need a rivet snap for the 5/32 rivets.
http://www.aircraft-tool.com/shop/de... .asp?PageNo=3
And a bucking bar
http://www.aircraft-tool.com/shop/de... .asp?PageNo=1
Old 08-16-2004, 04:08 PM
markdoane
Greg,
Thanks for the info. I was thinking about http://www.aircraft-tool.com/shop/de...t.asp?PageNo=1, but I can find the same model # $10 cheaper somewhere else. Do you think the 'economy' model is good enough?
vB code is On
Pingbacks are On
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 05:51 PM
Ebay rivet shaver TomW Ribs, Skins & Rivets 4 02-26-2004 01:54 PM
Olympic rivet tools smallfry Ribs, Skins & Rivets 4 02-10-2004 12:14 PM
Rivet Removal pap Ribs, Skins & Rivets 11 02-06-2004 10:04 PM
Blind and solid rivet tools wanted markdoane For Sale & Wanted 0 01-09-2004 05:19 PM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
