[quote=wahoonc]Ken, the air riveter doesn't use that much air because it is a short cycle not continous like a sander, shear or air chisel.
Thats what I had figured, but wanted to make sure - each rivet takes about 2-3 seconds to set from what I understand, so its not in constant use and I figured at that rate, the compressor would have lots of time to catch up. My compresser does recover pretty quickly when it does come on.
Tools are good
Ken
Ken,
I have a small air hammer which has a regulator built into it. I used it on full power to convince some rusted bolts on my frame to come out, and it did not require much cfm. My compressor is a 5hp tank type, and it does not work hardly at all with the air hammer. Die grinders and sanders require huge cfm, but the air hammer, air shear,and air ratchets usually work very well with smaller compressors.
I am going to try some riveting tomorrow, just got rivets and shank and bucking bar yesterday at aircraft spruce. If my air hammer does not workj well enough, then I will get a better one from aircraft spruce.
Indeed, tools are good!
It's a Chicago Pneumatic zip gun, model CP-711, model A. It's very useful for splitting mufflers.
OK, you caught me in a slight exaggeration. It's not really on/off, just seems like it compared to the new rivet gun. If I turn the pressure down low enough to match the lowest BPM of the rivet gun, the piston tends to jam.
The rivet gun has a lighter piston and runs slower at max throttle. I guess this is a case where I had to suck it up and spend the money.
Yes a rivet gun does cost a whole lot more than an air hammer. I have used both and really don't see that it is so far apart. The real key in bucking rivets is to use short trigger bursts and to keep pressure against the rivet head.
In turning down the air hammer's pressure I only turn down to around 75 psi and it still works fine.
If I were to have to replace my rivet gun today I really think I would just buy an air hammer instead.
__________________ Just adding my 2¢ worth
John G ___________________________ 1975 31ft Sovereign International ........Rear Bath Double Bed Model Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr System: Jordon 2020 Ultima Brake Controller Hook-Up: Equalizing Hitch and Sway Bar
Don't forget air tool maintenance. Oil them before and after use, to keep things from jamming and rusting. Compressed air contains a lot of moisture, which can ruin an air tool in no time.
Water seperators, and filters are a good investment if you use the air tool very frequently. Especially if you run expensive tools.
Good advice, thanks. I have a water separator and an oiler, but I still put a shot of oil in the butt end before I use them.
I haven't been oiling them after use, which is probably why I had to take my air drill apart and fix the throttle, it had gotten gummed up after sitting too long.
There's a fine line between a hobby and a mental illness.
Hmmm thanks for the reminder Uwe - I too oil before each use, never really think about after use. While we are at reminders, don't forget to drain the tank from time to time. That is something I do often when I'm finish using it - I let the air out of the drain valve to get whatever watar is in there out.
Let me know how the bucking goes - I'm almost there been reading all I can about bucking rivets - the best I can see is not too much, not too little - hope thats not easier said than done.
I'm not bucking rivets yet, but I am bucking 'nails'
I'm putting a band of 1/8" aluminum around the edge of the plywood in the rear, to protect the epoxy sealed end grain.
I found it darn near impossible to drive the aluminum nails in without bending them. It's an awkward position, what with the bumper in the way.
So I put a 1/8" set in my new rivet gun and used it to drive the nails. Sure works great.
Wow, you're actually using it as a hammer. That's something I never thought of. Glad to hear it works out ok. Got to remember this one....................
Ordered my 'tools' a few minutes ago from Aircraft Tool supply.
Got the 2602 rivet gun, two bucking bars, set of sets (?), two bags of 5/32 rivets, 75 Clecos and pliers, pressure regulator, deburring tools. Total was $236., with free shipping.
So if anyone needs something riveted in Minneapolis, give me a call. I want something to practice on before I start working on my own trailer.
Hi Don,
I wanted to know how this gun worked out? I will be purchasing one shortly and this seems to be the best deal. Please give me any info or suggestions you have. I just want to be sure this will be a good gun.
If I could jump in - I bought a $10 rivet gun from Harbor Freight which seems to work great (thanks to Uwe for suggestion) and bought all different sizes of rivets, bucking bar, rivet set and clecos from Aircraft Spruce.
The rivet gun worked out great! Same for the set, bucking bars, clecos.
I made an estimate of how many rivets I needed of each length I needed. As usual, I made a spreadsheet, with entries for how many layers of which thickness aluminum I would be riveting, and conversion factor from decimals to 16ths to rivet length. Very anal.
So I guess for doing a shell-off, and replacement of one side sheet, I think I used about a half pound of 5's, a pound of 6's, half a pound of 7's.
As a chicken...t buyer of a new 22ft CCD (forgive me and think of it as "future vintage") I didn't want to appear dumb enough to ask "what is a Cleco" - so I did a google search and there's a bunch of Cleco stuff on ebay right now.
I don't know if it's a good deal, but if you're looking...
Ken J
I went to Harbor Freight and the only rivet guns they had were the blind rivet type. They did have some cheap air hammers. Is this what you meant? Can you fit the rivet set inside any air hammer?
