Old 12-19-2010, 08:06 AM   #1
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Rivet Source
See the rivets holding the small metal plate on the door jamb. Where can I get these and will my rivet gun work on them? Is this plate some add on by a PO? Which is mounted in such a way that the upper hinge on the screen door pushes against it when closed. It actually racks the door frame and over the years has caused the frame to crack.
Old 12-19-2010, 08:52 AM   #2
Historically, screen doors crack, because of vibrations, when towing.
Old 12-19-2010, 09:57 AM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
The rivets look like the big headed ones used on the belly pan,Vintage Trailer Supply sells them. Dave
easyride is offline   Reply With Quote
Old 12-19-2010, 10:10 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Will your rivet gun work with the bigger rivets? Depends. If you have interchangeable tips with different sized holes, then yes it should work. Typically, the rivet guns that have interchangeable tips come with 4 different sized tips. One of them should be the right size.
Chris
Old 12-19-2010, 10:25 AM   #5
It appears that the added p-late is nothing more than a "shim" to move the screen door a little closer to the latch.
All you need to do to open the screen door, pull it a little from the edge towards you.
It doesn't take much to bend the hinges, so don't pull too hard the first time or two.
Then, you won't need those rivets.
Also, Home Depot stocks pop rivets.
Pop rivet source C_Ferguson General Interior Topics 11 03-28-2008 04:03 AM
Is this a rivet??? tinbender General Interior Topics 6 11-25-2007 03:29 PM
I've got a rivet, I've got a rivet! wannastream Our Community 9 03-17-2007 08:27 PM
Rivet knjobrien5 Forum Admin, News and Member Account Info 4 12-07-2005 09:35 PM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 04:41 AM
