Old 06-02-2009, 12:35 PM   #1
Lake Orion , Michigan
Rivet sizes
Okay new guy (me) is going to loosen and/or remove interior lower panels to access c-channel----Did I read somewhere to use a 1/8th inch drill and buy a 10 pack. Also what size rivet goes back in? 1980 Excella II 31'--
Also the c-channel at the 4 radiuses does not have a bottom shelf to the channel(so it's not a c-channel in those areas) 1/2" plywood has come loose from the so called c-channel in the gaucho arms and rear twin bed areas. So much for monocoque! And do we really need insulation under the floor ?
Thanks, Bud & Nan -bought AS last weekend--oh boy we're having fun now!
budal is offline   Reply With Quote
Old 06-02-2009, 12:43 PM   #2
The correct drill bit sizes for all Airstream work are, #30, #21 and #11.
#30 is used to remove the interior pop rivets and the exterior buck rivets.
#21 is used for Olympic rivets. Drilling buck rivets with a #30 first and then enlarging the hole with a #21 drill bit, is as near perfect as you can get.
#11 is used for 3/16 pop rivets that should be in the underbelly.
#45 or #48 white pop rivets are used in the interior.
Old 06-02-2009, 05:58 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If you can't find the numbered bits above. You will probably find 1/8' bit is just a hair small. If it works great. If not use a 9/32"
Tank Sizes?? rhoward On The Road... 6 02-07-2008 10:56 PM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 04:41 AM
sizes Elaine and Bohdan Airstream Trailer Forums 3 04-24-2003 09:54 AM
Wrench Sizes rmmm68 General Repair Forum 1 01-14-2003 01:05 PM
Help with definitions/sizes Tamara Airstream Trailer Forums 8 06-01-2002 10:06 PM
